type-r tranny or not? you tell me!
I just bought what i thought was an itr tranny(96) which is supposed to have lsd. i know that the 98 and up trannies have a stamp on the tranny that says that L-S-D. well this one dosen't is there any way really to tell b/c i really didnt want to tear it apart to find out. it does have an inscription on the tranny that might help someone help me figure it out it says: YSK 2 and for what is worth the serial is: S80-3025448 i did see the motor that it came of and the motor was a b18C (the j-spec type-r) i dont know if any of that will help you or not but my gs-r tranny has that same YSK 2 inscription did i get ripped or is the tranny legit. oh! the tranny hasen't been put on yet incase you were wondering. i was wondering if there was a way to tell before i put it in.
thanks!
thanks!
look through the hole that the axles go in if you can see through it its an lsd equipped tranny , if it has a bar through it then its non lsd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRex99 »</TD></TR><TR><TD CLASS="quote">
sorry it took so long to write back but i couldnt figure out how to find my add i looked at the tranny and i could see straight through it. So for future reference if you cant see through the axle holes than it is not an lsd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 »</TD></TR><TR><TD CLASS="quote">So for future reference if you cant see through the axle holes than it is not an lsd
Thats a pretty common myth that isn't always true. They still have a pinion shaft, its just of a different type. Sometimes possie's will have the bar right thru like open diffs.
</TD></TR></TABLE>Thats a pretty common myth that isn't always true. They still have a pinion shaft, its just of a different type. Sometimes possie's will have the bar right thru like open diffs.
blade0314
Apr 10, 2008 01:21 PM
