Oil Cooling
Old Apr 1, 2005 | 08:26 PM
^AnDre^'s Avatar
Default Oil Cooling
I know that using a remote oil filter in a race car set up = disaster if im not mistaken. However, I wuold like to know what is a good way to cool the oil through an oil cooler and safely. Note that the car is a 89 civic dx only used as a solo 1 and track day car (not road legal) also that it came with a oil cooler with remote oil filter.
any suggestions ?
Old Apr 2, 2005 | 12:20 AM
hybrid_vtec's Avatar
Default Re: Oil Cooling (^AnDre^)
Im curious too, b/c Ive been thinking of usong an oil cooler.
Old Apr 2, 2005 | 08:18 PM
euG3dc2r's Avatar
I'm not really sure what you mean by "safely" but I've been using a Greddy oil cooler kit on a DC2R (ITR) for over a year now with around 1000 track miles
- no issues or leaking
However to keep the oil temp down you'll also need
- low temp thermostat
- low temp fan switch
and look into a bigger radiator (depends how hard u push it)
This is aiming for a track oil temp of 85 degrees C.
Old Apr 3, 2005 | 12:33 AM
Default Re: (euG3dc2r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euG3dc2r &raquo;</TD></TR><TR><TD CLASS="quote">I'm not really sure what you mean by "safely" but I've been using a Greddy oil cooler kit on a DC2R (ITR) for over a year now with around 1000 track miles
This is aiming for a track oil temp of 85 degrees C.</TD></TR></TABLE>
Old Apr 3, 2005 | 12:58 AM
SSS's Avatar
SSS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^AnDre^ &raquo;</TD></TR><TR><TD CLASS="quote">I know that using a remote oil filter in a race car set up = disaster if im not mistaken. </TD></TR></TABLE>
What makes you say that just out of curiosity?
Old Apr 3, 2005 | 07:40 AM
^AnDre^'s Avatar
Default Re: Oil Cooling (SSS)
http://www.hadamotorsport.com/....html
this was put up by Toronto's major solo 1 organization... this is my basis.
Old Apr 3, 2005 | 07:41 AM
^AnDre^'s Avatar
sorry, forgot to add choose "How To Blow Up an Engine (or two)". second one down form the top (how to)
Old Apr 3, 2005 | 09:12 AM
Wes V's Avatar
Dang, don't use that as a reason to question the safety of a remote oil cooler!! They admit to plumbing the filter backward!!!!
I don't see any reason to not run a remote cooler (unlike the oil inter-cooler on a GSR) but would recommend adding a thermostat to the system.
Use 1/2" plumbing.
Mount the filter as low as possible so that it doesn't bleed down (when the engine is turned off) which could lead to low pressure upon start-up.
It's all in the details!
Wes
Austin
Dec 31, 2017 02:56 PM
mrlegoman
Aug 4, 2009 10:03 AM
2khb
Oct 13, 2008 12:47 PM
migs
Jul 24, 2006 07:10 PM
90crxzc
Dec 6, 2003 01:36 PM
