torque specs on z6 n/ distro timing
Old Apr 1, 2005 | 08:16 PM
user 98292739's Avatar
Default torque specs on z6 n/ distro timing
are the torque specs on the a6 the same as the z6? because i need to know what i need to torque down the rocker arm assembly. on the a6 its 16lbs. and on the distro do i just stick it in anyway it fits on the cam? or eh? and what is the firing/cylinder order? thx!
Old Apr 1, 2005 | 08:26 PM
mr. carpenter's Avatar
Default Re: torque specs on z6 n/ distro timing (LoCoReX)
put the dist. on like this if your still using the a6 dist.
https://honda-tech.com/zerothread?id=913151
Old Apr 1, 2005 | 09:30 PM
hey man thx alot but i have a z6 dizzy
Old Apr 1, 2005 | 09:31 PM
blackeg's Avatar
Default Re: torque specs on z6 n/ distro timing (mr. carpenter)
the longer bolts are 16 ft/lbs, the shorter ones are 9 ft/lbs.
firing order is 1.3.4.2
Old Apr 2, 2005 | 05:34 AM
so order is
1 3
4 2 ?and cylinder 1 is the one right next to the cap?
Old Apr 2, 2005 | 06:07 AM
Default Re: (LoCoReX)
also found this thread.
https://honda-tech.com/zerothread?id=821403
G3NR8
Apr 6, 2006 08:08 AM
IDriveHonda
Nov 8, 2003 09:56 AM
ShiroX
Jan 3, 2003 10:25 PM
