ZC NO start....help
Old Apr 1, 2005 | 08:02 PM
crexer's Avatar
Default ZC NO start....help
Car has sat for a while but finally got it up and running the other day and I tried to pull it inside today and it wouldnt start. The starter is not clicking, we have tried 2 known good ones and neither will click. Tried 2 good known batteries. Grounds are all good, fuses are all good, no codes, if you hook a test light up from 1 of the starters power wires the light seems to have a weak signal. Nothing happens when I turn the key. This is my friends car by the way so sorry if it sounds sketchy. What could I check for? Does the starter also have a ground or is it grounded through the bolts that hold it on?
Old Apr 2, 2005 | 08:32 AM
crexer's Avatar
Default Re: ZC NO start....help (crexer)
what would cause the starter to NOT click??
Old Apr 2, 2005 | 02:05 PM
crexer's Avatar
thanks for all the help
Old Apr 2, 2005 | 02:09 PM
88ED8's Avatar
check the clutch switch
Old Apr 2, 2005 | 02:11 PM
mr. carpenter's Avatar
the solenoid is probably bad.
turbo-crx
Aug 3, 2008 12:02 PM
Pockets
Dec 19, 2007 05:24 PM
EG6-SIRII
Jan 12, 2007 01:50 PM
morphics
34
Nov 4, 2005 05:41 AM
Int3Gra147
Apr 30, 2003 12:37 PM
