Question about my 98+ Headlights.
Alright I have a questions about these headlights I have. If you look in the picture below theres a tab missing from one the headlights. The other headlight has it while the 1st one does not. I think that tab is the leveler for the headlights I'm not sure. My question is can I still use the headlight without the leveler if that is what it is.
1st headlight no tab
2nd headlight with tab
Both pictured left one has no tab while the right one does.
Left/right aim indicator is missing... the level indicator is located under the sightglass. Take a trip to the junk yard some time and remove it from any 94+ integra. They are side specific so make sure you grab the right one, or use the one from your 94-97's (if you're doing a conversion).
If you choose not to run the aim indicator make sure the hole isn't open, wrap it so no moisture gets in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">Left/right aim indicator is missing... the level indicator is located under the sightglass. Take a trip to the junk yard some time and remove it from any 94+ integra. They are side specific so make sure you grab the right one, or use the one from your 94-97's (if you're doing a conversion).
If you choose not to run the aim indicator make sure the hole isn't open, wrap it so no moisture gets in.</TD></TR></TABLE>
Yea I'm doing a conversion so I guess I'll take it off my old ones. Are you sure the ones from my 94-97 lights will fit? Any other opinions?
Modified by iixerOii at 11:51 AM 4/2/2005
Hybridcrx469
Nov 8, 2004 04:27 PM
