How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork
Old Apr 1, 2005 | 05:20 PM
xunkn0vvnx's Avatar
Default How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork
In an attempt to ride my integra of Clutch Squeak I am taking the advice of fellow HT'ers and plan on lubing the master/slave cylinder, throwout bearing, and clutch fork. I have a haynes manual but do not find it very useful. How would I go about completing these tasks ?? I have already WD 40'd the clutch springs so that is not the problem.
Here are some pictures of under the dash, from up top of the engine bay, and downlow of the engine bay. Can someone point out what is what ?? and what i need to lube ?? Also if disassembly is needed.
Top of engine bay:
Beneath Car:
Under Dash:
Modified by xunkn0vvnx at 9:41 PM 4/1/2005
Old Apr 1, 2005 | 06:10 PM
Dan GSR's Avatar
Default Re: How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork (xunkn0vvnx)
1. your pictures suck ***
2. you never spray anything on your clutch, especially WD40
3. if you want to get rid of your squeak, pull back the boot that covers the clutch fork, and grease the ball and socket
Old Apr 1, 2005 | 06:37 PM
.RJ's Avatar
.RJ
Default Re: How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">3. if you want to get rid of your squeak, pull back the boot that covers the clutch fork, and grease the ball and socket</TD></TR></TABLE>
And the clutch pedal inside the car
Old Apr 1, 2005 | 08:18 PM
01-0720's Avatar
Default Re: How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork (.RJ)
RESIZE YOUR PICTURES DUMBASS THERE FREAKIN HUGE, IV GOT A CABLE MODEM AND IT TOOK 5 ******* MINTUES FOR THE PAGE TO LOAD
Old Apr 1, 2005 | 08:43 PM
xunkn0vvnx's Avatar
Is the boot that covers the clutch fork in that picture ?? Also what part of the clutch do I grease ?? I am so lost
Old Apr 1, 2005 | 09:08 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xunkn0vvnx &raquo;</TD></TR><TR><TD CLASS="quote">Is the boot that covers the clutch fork in that picture ?? </TD></TR></TABLE>
No
take it to a mechanic
Old Apr 2, 2005 | 06:42 AM
KayOs's Avatar
The initiative to resolve your problem is duly noted, but it seems that it's best you leave it to someone professional to perform.
Old Apr 2, 2005 | 09:20 AM
xunkn0vvnx's Avatar
Default Re: How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork (KayOs)
how so ?? pulling back a rubber boot and greasing, in theory does not seem very hard.
Old Apr 2, 2005 | 09:36 AM
Kenso's Avatar
HT White Ops
The boot in your pics is on the steering rack, not the clutch slave cylinder/fork area.
Old Apr 4, 2005 | 04:02 PM
integratom's Avatar
Default Re: How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork (Kenso)
Let me clear up something the actual squeak is coming from the the pivot point of the fork in the trans. It seems as though its coming from inside but its just that the sound sort of travels through the line causing the noise to seem as if it were inside. You need to remove the slave cylinder set it aside best you can, then remove the boot and try to use mirrors or whatever so you can see in there. Then using some form of lliquid lube (wd-40 will not last more thatn a week or so) you need to get the lube into the pivot. Yes it is much harder to do than it sounds. The only real proper way to do it is R&R trans lube a pivots with a good quality grease. Big hassle I know but I'm in the same boat and need to take care of it soon too it's driving me nuts...... Well hope I cleared things up for ya
Old Apr 4, 2005 | 06:30 PM
xunkn0vvnx's Avatar
Default Re: How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork (integratom)
wow thats hard !
Javelin
Sep 29, 2015 07:17 PM
nothome17
Acura TSX
Sep 30, 2010 11:06 AM
xunkn0vvnx
Apr 4, 2005 12:50 AM
junglistgsr
Dec 7, 2001 10:27 AM
