help
Old Apr 1, 2005 | 03:10 PM
pdorow's Avatar
Default help
my car would start to stuter and almost die when you were cruisin at an rpm when it was cold. well today on my way to work i was at a stop sign and it died. it is not a broken timing belt, i put new plugs in it and checked the coil does anyone else have any ideas please help.
Old Apr 1, 2005 | 03:16 PM
SpOoNisMyFriEnD's Avatar
sounds like a fuel problem....maybe one of the injectors are clogged...but hell what do i know!
Old Apr 1, 2005 | 03:22 PM
pdorow's Avatar
gettin lots of fuel and died right away so i dont think its an ingector. i think it might be ignition control module.
Old Apr 1, 2005 | 03:30 PM
e jay one's Avatar
Default Re: (pdorow)
is there a cel? if your timing belt was broke your car wouldnt even run.
Old Apr 1, 2005 | 03:31 PM
pdorow's Avatar
car doesnt run it died at stop sign and wont run anymore.
Old Apr 1, 2005 | 03:36 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: help (pdorow)
Are you getting spark?
You mentioned you recently changed the coil and spark plugs, yes, it could be the ICM or ignitor causing problems. Did you move the set timing of the distributor when you removed it to put the coil in?
Old Apr 1, 2005 | 04:39 PM
B16aDasher's Avatar
Default Re: help (INVALID)
yeah, Sound like a fuel problem.
Old Apr 1, 2005 | 07:17 PM
if it was the ignitor wouldnt the rpm tach be all fucked up.....??
Old Apr 2, 2005 | 08:20 AM
pdorow's Avatar
no tach and heres a bump
96delsol123
28
Mar 30, 2013 08:51 PM
lsvtek
May 11, 2008 11:06 PM
reed857
May 18, 2005 10:04 AM
I-VTECRX
Feb 24, 2005 04:05 PM
