washers to correct rear camber
I installed a set of zeal B2's this weekend. i lowered the car about 1.25" from the stock height, the camber dosen't look too bad, but i was considering using the washer trick to fix it in the rear. What thickness washers should i start with? will i need longer bolts? are grade 8 bolts and washers good enough to use? I am taking the car for an alignment tomorrow, so i will see how much its off by.
jena_blondie
Nov 12, 2009 08:33 PM
FourthGenHatch
11
Oct 1, 2002 07:00 PM
