NO SPARK
I CANT GET ANY SPARK I PUT MY EAR TO the gas tank to see if the fule pump work wich lets me no that its not the crankshaft sensor i had my distubuter rebuilt but havent checked my ecu can anyone help r there any other things i should check
The engine doesn't even need to turn over for the fuel pump to prime. A priming fuel pump is not an indication of a functioning CKP/CYL/TDC sensor.
What about your distributor did you have rebuilt?
Are you getting any codes?
P.S. Work on your sentence structure.
Atomic Ant
Oct 16, 2017 11:01 PM
