Failing FPR...NEED HELP QUICK??????
Old Apr 1, 2005 | 09:49 AM
EFz6er's Avatar
Default Failing FPR...NEED HELP QUICK??????
Im cruising at 40mph and all of a sudden I smell gas...look out the rear window and see white-ish smoke pouring out and I cant rev higher than 3000rpm...its like a fuel cut off/redline at that point.
Im thinking its my FPR....sound right? Right now Im stranded at work. I need a quick solution. Is it OK to drive like this to a shop or auto parts store?
Old Apr 1, 2005 | 10:01 AM
EP3_05's Avatar
Default Re: Failing FPR...NEED HELP QUICK?????? (EFz6er)
Hmmm....any ecu error codes? White smoke is usually coolant or oil. A dark grey or black smoke indicates excess fuel.
Old Apr 1, 2005 | 10:02 AM
EFz6er's Avatar
Default Re: Failing FPR...NEED HELP QUICK?????? (91civic)
I have codes 14 (IACV) and 43 (fuel system supply)
Old Apr 1, 2005 | 10:03 AM
EP3_05's Avatar
Fix the codes....what engine and ecu are you running? I think d16z6 but not sure?
Old Apr 1, 2005 | 10:06 AM
EFz6er's Avatar
its a 90 hatch with B18a1 swap...just went to check and see if there are more codes and now there are
code 1 -02 sensor
code 14- IACV
Code 16-fuel injectors
code 43- fuel system supply
Is is safe to drive to the shop while its running so rich like this. Its only like 5 miles at most.
Modified by EFz6er at 1:45 PM 4/1/2005
Old Apr 1, 2005 | 10:14 AM
EP3_05's Avatar
It should be ok. Just takeit easy and baby it there. If you are so worried just tow it.
godixon
Mar 28, 2014 03:56 AM
95civic16
May 18, 2009 08:01 PM
SsB_Db8
Jul 14, 2007 11:25 PM
.I.Need.Money.
Jun 10, 2006 12:07 PM
Cole D
Jul 10, 2003 08:25 PM
