Suspension & Brakes Theory, alignment, spring rates....
Integra and 99+ Civic Si rear swaybar endlinks the same?
Old Apr 1, 2005 | 08:55 AM
Thirty-Nine's Avatar
Default Integra and 99+ Civic Si rear swaybar endlinks the same?
I've got a rear swaybar and brackets for a 99-00 Civic Si rear swaybar, but I need the endlinks to go on a 98 Civic EX.
Will 94+ Integra rear swaybar endlinks work for on a 96-00 Civic EX, or do I just have to get the Si endlinks?
Old Apr 1, 2005 | 01:52 PM
gabebauman's Avatar
Default Re: Integra and 99+ Civic Si rear swaybar endlinks the same? (Sushiboy)
No...you need the si endlinks.
Old Apr 14, 2005 | 11:00 PM
JDM SLICK's Avatar
Default Re: Integra and 99+ Civic Si rear swaybar endlinks the same? (gabebauman)
yeah what he said...
Old Apr 26, 2005 | 03:24 PM
Circuit Star-29's Avatar
Default Re: Integra and 99+ Civic Si rear swaybar endlinks the same? (JDM ***)
YOu can use any enlinks you want...I wouldn't recommend the Si links though.
Old Apr 27, 2005 | 05:15 AM
Default Re: Integra and 99+ Civic Si rear swaybar endlinks the same? (C-speed Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Racing &raquo;</TD></TR><TR><TD CLASS="quote">YOu can use any enlinks you want...I wouldn't recommend the Si links though.</TD></TR></TABLE>
What do you mean? Can you clarify a bit more?
Old Apr 27, 2005 | 07:42 AM
94eg!'s Avatar
#1 Super Guy
Loved
Integra endlinks won't work properly since they are designed to be mounted on top of the LCA and not in the middle (EK style). Just order/find a set of EK endlinks and you should be good. You can also try to order some Heim Joints w/ custom bushings from A-Spec-Racing.com. They sell a whole swaybar kit, but they may sell you just some of the parts...
Old Apr 27, 2005 | 08:16 AM
Default Re: Integra and 99+ Civic Si rear swaybar endlinks the same? (94eg!)
Co worker is using Teg links on a Si...They work fine.
Also, Si links are weak and if you get a larger rear bar then you risk snapping the links.
Old Apr 27, 2005 | 04:34 PM
I don't care about weak. It's just for a daily driver.
Old Apr 27, 2005 | 11:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sushiboy &raquo;</TD></TR><TR><TD CLASS="quote">I don't care about weak. It's just for a daily driver. </TD></TR></TABLE>
Famous last words....
Build to last, ALWAYS!!! No matter what it is...
Old Apr 28, 2005 | 05:03 AM
It's my wife's car. She drives it to work and back. I have a bar laying in my garage that's been there for a year. If the 99-00 bar and links are good enough for a 99-00 Si, they'll be just fine for a 98 EX sedan. Plus, I don't want anything larger that I'll have to worry about ripping the subframe.
Old Apr 28, 2005 | 06:27 AM
gabebauman's Avatar
Yes...you'll be fine with the si endlinks...the bar is only 13mm to begin with anyway.
Old Apr 28, 2005 | 10:44 AM
Yeah, only 13mm...no worries there...
Old Apr 28, 2005 | 02:20 PM
SOHC4life 96's Avatar
Not trying to thread jack, but if I wanted to use the 22mm ITR bar on my 96 ex coupe, what endlinks should I use?
Old Apr 29, 2005 | 09:02 AM
Default Re: Integra and 99+ Civic Si rear swaybar endlinks the same? (SOHC4life 96)
I don't know, but I'd be careful. Even with the Beaks subframe reinforcement kit, people have ripped their rear subframes with big bars on EXs.
Old Apr 29, 2005 | 09:18 AM
94eg!'s Avatar
#1 Super Guy
Loved
Check out http://www.A-Spec-Racing.com. They sell a 22mm Type R sway/tie bar kit for the EK that is top notch. They also include your choice of either EK endlinks or Heim joints (spherical bearing endlinks). It's a bit of money, but well worth it for the peace of mind. They also make a 32mm hollow sway bar that could be purchased later, that bolts onto their reinforcment plate...
You could also go with the more expensive, but adjustable 22mm Comptech sway/tie bar combo...
Old Apr 29, 2005 | 09:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to thread jack, but if I wanted to use the 22mm ITR bar on my 96 ex coupe, what endlinks should I use?</TD></TR></TABLE>
Integra endlinks
99civic_exSB
26
Jul 9, 2003 09:32 PM
EricUSC
Feb 22, 2003 08:55 PM
EricUSC
12
Jan 27, 2003 03:22 PM
EricUSC
Jan 15, 2003 11:22 AM
stevel
Jul 24, 2001 11:27 PM
