B18A block with GSR rotating assembly?
Okay, I already searched.
I'd like to know how GSR internals would work inside a B18A block, I've been thinking about building a GSR block for the future (Poor man's R build...), but then I started to think about running a GSR crank w/ rods/girdle in my LS block. How would that work, and how would it effect the compression ratio?
All your numbers would be the same as a gsr (comp. ratio,displacement).The only difference is the need for external oil line and no squirters.
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">All your numbers would be the same as a gsr (comp. ratio,displacement).The only difference is the need for external oil line and no squirters.
Glenn</TD></TR></TABLE>
No need for external oil line? I'm talking about using the GSR internals, in the LS block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
No need for external oil line? I'm talking about using the GSR internals, in the LS block.</TD></TR></TABLE>
I figured vtec head from your sig.
Glenn
Glenn
'00 Si head, but i'll still be running the non VTEC block if I choose to put the GSR internals in my B18A, instead of buying a GSR block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">'00 Si head, but i'll still be running the non VTEC block if I choose to put the GSR internals in my B18A, instead of buying a GSR block.</TD></TR></TABLE>
all he is saying is that you will still need the oil line from the ls block to the vtec head.
fatpride111
Apr 10, 2008 06:08 AM
marcussmith26
Dec 5, 2005 05:28 PM
1quickhatch
46
Feb 1, 2005 11:40 PM
