semi-built gsr motor f/s...
Old Mar 31, 2005 | 08:19 PM
scUba-stEve's Avatar
Default semi-built gsr motor f/s...
JG pro series b16 head
JG stainless steel valves
rocket motorsports springs/retainers
aem fuel rail
dsm 450cc injectors
ITR intake manifold(port matched)
ITR throttle body(65mm)
4-1 stainless steel header(from JDMshit.com)
skunk2 cam gears
buddy club spec 4 cams
cometic headgasket
b18c1 block
81.5mm bore
wiseco 11.8:1CR(with the head being milled and decking the block, the CR should be close to 12.2-12.5:1)
eagle h-beam rods
micropolished crank
acl bearings
full rotating assembly blueprinted and balanced
golden eagle block guard
brand new seals(head and block)
new water pump/timing belt/oil pump
looking to sell this as a complete LONGBLOCK for 4700...or 5500 with a b16 tranny with ITR LSD...i would consider trades like a d16z6+cash, or b16+cash...but i need at least 3500 cash or more.
also have a p28 with hondata s100 for a extra too...this motor will definately be pushing out well over 200 whp...the motor has been in my car for about 500 miles(breaking it in)...you can come look at it and drive it...but i need the money.
Old Mar 31, 2005 | 10:12 PM
Default Re: semi-built gsr motor f/s... (zer0-psi)
bump.
Old Apr 1, 2005 | 06:01 PM
up, up, and away.
Old Apr 2, 2005 | 10:57 AM
bump this.
Old Apr 14, 2005 | 07:29 PM
sexyblack93lude's Avatar
how much you lookin for , for your motor
scUba-stEve
Northwest (Sales)
14
Oct 14, 2005 12:38 AM
VtecKiDD
Dec 13, 2004 07:02 AM
chris@allmotor.net
Feb 13, 2004 01:11 PM
EVOCELICA
Sep 2, 2002 01:04 PM
