Another lame transmission fluid question.
Old Mar 31, 2005 | 07:18 PM
Sack Master's Avatar
Default Another lame transmission fluid question.
I don't want to start an arguement over which is better or why. I really just want to know what Acura recommends for a type-r tranny. I have a gs-r and in my owners manual it says MTF or 5w30 motor oil. I won't be running MTF. Which is all I see by searching. Use MTF or use synchromesh ETC ETC.
I just want to know if honda says to use a friction modifier or not. Thanks for your help
Old Mar 31, 2005 | 07:19 PM
B2FiNiTY's Avatar
Default Re: Another lame transmission fluid question. (Sack Master)
Honda/Acura recommends Honda MTF. DONE.
Old Mar 31, 2005 | 07:29 PM
Default Re: Another lame transmission fluid question. (B2FiNiTY)
I know for a gs-r they recommend mtf or regular motor oil(in the owners manual). I didn't know if it was different for a type-r tranny.
Is the differential a clutch type posi unit that requires a friction modifier? Thats what I really need to know. TIA
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Honda/Acura recommends Honda MTF. DONE. </TD></TR></TABLE>
Old Mar 31, 2005 | 07:46 PM
.RJ's Avatar
.RJ
https://honda-tech.com/zerosearch
My head a splode
Old Mar 31, 2005 | 08:03 PM
KayOs's Avatar
Default Re: Another lame transmission fluid question. (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerosearch
My head a splode</TD></TR></TABLE>
Kaboom
Old Mar 31, 2005 | 08:12 PM
Default Re: Another lame transmission fluid question. (KayOs)
Sweet I didn't think of that. Thanks guys. A simple answer would have been sufficient.
Old Mar 31, 2005 | 09:56 PM
hadboosttroy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Sweet I didn't think of that. Thanks guys. A simple answer would have been sufficient. </TD></TR></TABLE>
a simple search would have also been sufficient
Old Apr 3, 2005 | 12:46 AM
silentblackhat's Avatar
Default Re: Another lame transmission fluid question. (hadboosttroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy &raquo;</TD></TR><TR><TD CLASS="quote">
a simple search would have also been sufficient</TD></TR></TABLE>
to that
Old Apr 3, 2005 | 04:17 AM
Utilitarian's Avatar
Don't forget, she likes it when I put it in her VSS!
Old Apr 3, 2005 | 06:18 AM
Justin Klemgold's Avatar
My manual says "Use oil as a TEMPORARY replacement." It says nothing about substituting it for the MTF.
Old Apr 3, 2005 | 06:23 AM
DragII's Avatar
25 Year Member
Old Apr 3, 2005 | 09:12 AM
Default Re: (Justin Klemgold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">My manual says "Use oil as a TEMPORARY replacement." It says nothing about substituting it for the MTF.</TD></TR></TABLE>
Very true, mine says use as a temp replacement until MTF iss avalable
Old Apr 3, 2005 | 01:52 PM
jaa1311's Avatar
just make sure you change your blinker fluid at the same time, always good to be safe
btw Honda MTF is all ive ever put in mine
Old Apr 3, 2005 | 02:22 PM
Padawan's Avatar
Darth ModerVader
Directly from the manual:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If Honda MTF is not available, you may use an API service SG, SH or SJ grade motor oil with a viscosity of SAE 10W-30 or 10W-40 as a temporary replacement. An SG grade is preferred, but an SH or SJ grade may be used if SG is not available. However, motor oil does not contain the proper additives and continued use can cause stiffer shifting. Replace as soon as convenient. </TD></TR></TABLE>
Old Apr 3, 2005 | 06:45 PM
Game....Set....Match
9cobra4
Apr 11, 2008 01:53 PM
1JDMDOMINICAN
Sep 23, 2005 12:38 PM
RAS Motorsports
Oct 10, 2004 12:11 PM
Cimburke23
Oct 8, 2004 06:53 AM
stealthteg
Jul 25, 2002 01:20 PM
