weird t25 turbine housing(56k beware)
Old Mar 31, 2005 | 03:20 PM
r_wiggum01's Avatar
Default weird t25 turbine housing(56k beware)
ok, i got this turbo off ebay, it's supposed to be a garrett t25. the inlet flange, and all the flanges on the compressor look like a normal t25, but it doesn't have a standard 5 bolt discharge flange. instead, it's got a 4-bolt flange that's shaped like the 5-bolt, only minus a bolt. if it helps at all, on the compressor it says m24 a/r .48, which i'm assuming to be a .48/.49 t25.
what did this turbo originally come off of? i've never seen that discharge flange before.
will i still be able to use a normal t25 downpipe flange with it?
if not, will i be able to swap out with a normal housing with the 5-bolt discharge? and where could i find one of these?
Here's some pics in case they help:
Old Mar 31, 2005 | 03:21 PM
Emshhh's Avatar
Nissan sr20 motor?
dsm maybe?
Old Mar 31, 2005 | 03:24 PM
r_wiggum01's Avatar
Default Re: (iGfrequency)
i thought it was from the sr20, but it's certainly not a standard discharge. it's definitely not dsm tho. dsm's have a rounded inlet flange and a much different discharge flange.
Old Apr 1, 2005 | 05:42 PM
r_wiggum01's Avatar
Default Re: (r_wiggum01)
bump for help. what's up with this flange?
Old Apr 1, 2005 | 05:44 PM
DragSource's Avatar
That is a T25G
Comes stock on a Nissan SR20DET
You will need a nissan style t25 flange - HKS makes manifolds for it.
Old Apr 1, 2005 | 05:46 PM
r_wiggum01's Avatar
Default Re: (DragSource)
i know what the inlet flange is, i need to know what's up with the discharge. the downpipe flange that normally comes on sr20det's is a 5 bolt flange, this has a four bolt, and i've never seen that before.
Old Apr 1, 2005 | 05:52 PM
DragSource's Avatar
I see what you're talking about. . . yeah they are usually 5 bolt hot sides. I'm looking into it. . . baffled right now.
Old Apr 1, 2005 | 05:53 PM
adeihl's Avatar
off of a 200sx i think. older style
Old Apr 1, 2005 | 06:00 PM
DragSource's Avatar
Is this the same bolt pattern?
Found at http://www.jblmk3.com/id114.htm
Leaving work or I'd look into it more - be home in an hour
Old Apr 1, 2005 | 06:09 PM
r_wiggum01's Avatar
that's very close, bolt are closer together on the right side tho, and there's a rounded section in between the bolts on the left side
Old Apr 1, 2005 | 06:28 PM
DragSource's Avatar
fuggin weird. . . I'm at home now - still looking.
Anything written on the turbine housing? an a/r or anything?
Old Apr 1, 2005 | 06:31 PM
r_wiggum01's Avatar
yeah, just found this earlier today. next to the inlet flange it says .54(i'm assuming this is the a/r) with "H1" written beneath it. by the discharge flange it says 686 13T Garrett 272-1
btw, thank you DragSource and everyone else trying to help.
Modified by r_wiggum01 at 7:44 PM 4/1/2005
Old Apr 1, 2005 | 06:43 PM
NitrousFed900's Avatar
Your best bet might be to fab a flange and DP ... jut my .02
Old Apr 1, 2005 | 06:46 PM
r_wiggum01's Avatar
Default Re: (NitrousFed900)
yeah, downpipe i already planned on fabbing. hoping to just find a replacement t25 housing with the 5 bolt discharge, as i will eventually replace this with a gt28rs and it would be nice to make it a bolt-on replacement.
Old Apr 1, 2005 | 08:21 PM
wantboost's Avatar
Who is Mr Robot?
could be off of a skyline... they have a funky discharge flange if i remember correctly
Old Apr 1, 2005 | 08:58 PM
r_wiggum01's Avatar
anybody have a blown t25 with 5-bolt housing they wanna sell as a whole or just the turbine housing? that would make things so much easier. suppose i oughtta make a WTB thread for this.
Old Apr 1, 2005 | 11:56 PM
Def's Avatar
Def
Definitely not an SR20DET T25, as those have 0.80 A/R compressor housings and 5 bolt turbine exits.
Looks like either a Z32 300ZX T25 or Skyline RB26 T28 to me - from the looks of it it looks like a 300ZX T25. Max out around 175-200whp(smaller than an SR T25 that will max out around 240-270whp).
Old Apr 2, 2005 | 02:33 AM
degradated's Avatar
New User
Default Re: (Def)
That's a stock turbo from a 90-96 300zx (minus actuator).
You can get a nice split downpipe for it from this place:
http://www.specialtyz.com/downpipes.htm
However, I'm not sure about clearance for whatever you're using it for... You'd also have to ask them if they could only sell you 1 downpipe (they are normally sold in pairs).
Old Apr 2, 2005 | 06:16 AM
r_wiggum01's Avatar
Default Re: (degradated)
thanks, Def and degradated, that's some helpful info. at least now i know it's usdm, i'll go to the nissan dealership and get a gasket for it and have a flange made. guess i'll just hafta chop it off later when i upgrade.
edit: eh, on second thought, i'll just ebay it. too much effort.
Old Apr 2, 2005 | 06:34 AM
DragSource's Avatar
Thanks guys. . . I knew it was nissan, lol.
Glad someone with more exp chimed in.
Old Apr 8, 2005 | 06:41 AM
14bcoupe's Avatar
yep he is right. go to the nissan dealer, thats one of the turbos i sold before who knows if its the same exact one lol. but a little more info its a pretty small turbo its one of the turbos from the twin turbo so you ll probably spool up at 2000rpm, will be a fun daily driver but dont expect anything after 5800 rpm.
503_EF9
Nov 13, 2008 11:17 PM
turbojeesx
Welding / Fabrication
Aug 11, 2008 03:58 PM
EX-T
Jun 26, 2007 05:33 PM
brent_G
Aug 22, 2005 01:55 PM
