spoon type r pistons and connecting rods
Old Mar 31, 2005 | 03:00 PM
highrevnef's Avatar
Default spoon type r pistons and connecting rods
i am getting a 92-95 gsr and before i put the motor in im planing on putting in spoon type r pistons and spoon type r connecting rods in the motor. And the block will be hot tanked and balanced crank shaft etc. my is going to be stock except for the intake and skunk 2 manifold. wut kind of power will i be looking at?
Old Mar 31, 2005 | 04:13 PM
95lstegman's Avatar
Default Re: spoon type r pistons and connecting rods (highrevnef)
maybe +5hp.
Old Apr 2, 2005 | 12:25 AM
327da9's Avatar
Arent the spoon type r pistons and rods just balanced by spoon.
Other than the 2 gram difference between the parts,
i would just save your money and get oem rods and pistons.
Old Apr 2, 2005 | 01:58 AM
Eclypz's Avatar
actually, you'd be surprised how much it helps to have lightened internals.....
2 grams might not sound like much, but imagine those 2 grams x 4 moving up and down at 8000+rpm.
the weight savings goes up exponentially as the revs climb.
Old Apr 2, 2005 | 02:04 AM
Kendall's Avatar
The biggest issue I have with Spoon balanced internals, is that many people will balance your stock stuff for much less than it would cost to buy the Spoon ****. If you're still hell-bent on P73 pistons, then I don't suppose it's a bad price considering the fact that the Spoon pistons include the rings.
Old Apr 3, 2005 | 09:10 PM
327da9's Avatar
Default Re: (Eclypz)
Im all for lighter internals.
I guess Kendall put into words what i was trying to describe instead.
I just dont see the point in paying for the "Spoon" markup , when a competent machine shop would be able to balance/blueprint the pistons and rods.
Old Apr 3, 2005 | 09:21 PM
Kendall's Avatar
Default Re: (Palmy Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to get them shot pinged so you dont throw one.</TD></TR></TABLE>
This is a rather bland statement. Shotpeening improves the grain structure in a metal, thus making it stronger. An all motor setup (what factory rods and Spoon balanced rods are intended for) usually will not stress the motor enough during proper driving conditions to ever flat out break a rod. Balancing the rotating assembly is critically important though. Unbalanced internals can become unstable at high rpms and cause any number of engine maladies.
hardparked
24
Oct 5, 2009 01:00 AM
highrevnef
Mar 31, 2005 04:42 PM
r2ck_p
Dec 21, 2004 06:55 AM
PYITR821
Jun 9, 2004 11:30 PM
Jockdeeznutz
Mar 31, 2004 09:40 AM
