Possible Blown Motor?
Alright...I was testing my car last night after my friend and I swaped my slave cylinder...and while I was doin a 4th gear pull on the freeway at about 120...it just died out. No CEL...no oil light...nothing. Slow down and try starting it again...the starter just cranks and there are little putts out the exhaust. The motor doesn't even shake. Tried push starting...nothing. Check the timing belt...fine. Check the spark plug wires...fine. Check the rotor...fine. Still gettin fuel. Checked number 1, 2, and 3 spark plugs...no oil. Checked the dipstick...no contamination. Checked all my connections...nothing loose. We re-spliced the wires for my MAF sensor on the ECU harness to un-bypass the MAF...didn't help. We are at a loss for what it could be.
It's a D16Z6 w/ a custom turbo kit.
Switched dizzys...no change
Any other ideas?...goin to do a compression test later tonight...see if that tells anything. My friend thinks it might be a spun bearing...anyone agree with this?
cylinder# 4 closer to the distributor the spark plug electrode part where it sparks ......its a closed gap now....can't even put a piece of paper through that and has a little metal shaving baked on it....
i am assuming i cracked my ringland....
any suggestion guys.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">hm yea that doesnt look good to me, is the angle or is there no gap?</TD></TR></TABLE>
No gap....and that is metal particles melted onto there too.
LilCivic04
Mar 7, 2005 06:21 PM
