welded diff. to make LSD
LSD+limited slip
Welded Diff=No slip
Why is it unsafe??
Both wheels spin at same speed around turns, one will be dragged along in essence, at some point in time
Not bad at 20-30 MPH
Highway speed could be a problem
Modified by civic-4-ges at 4:28 PM 4/1/2005
Welded Diff=No slip
Why is it unsafe??
Let's consider tire wear for one thing, the wheels will be at equal speeds regardless and during any kind of turning, this will create accelerated tire wear.
The tire wear results from one driving wheel getting correct traction and one spinning slightly. Lets take it a step further and consider what will happen during rain, or if the driver hits the brakes during a corner. One wheel is already past the point of normal adhesion as it can't move the correct speed when turning. So in limited traction environments once the remaining wheel starts to break loose, the car will become almost uncontrollable. Heavy braking during cornering will cause rather drastic understeer and may be unrecoverable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2nr »</TD></TR><TR><TD CLASS="quote">but if the car is a track toy then it works just fine
Depends upon what sort of "track" you're referring to.
</TD></TR></TABLE>Depends upon what sort of "track" you're referring to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Depends upon what sort of "track" you're referring to.
Right. A "strip" toy, it'd be nice. A "road course" toy, it'd suck and probably put you into a crashing situation.
</TD></TR></TABLE>Right. A "strip" toy, it'd be nice. A "road course" toy, it'd suck and probably put you into a crashing situation.
