Building a log mani.
Old Mar 30, 2005 | 11:13 PM
FranknStein's Avatar
Default Building a log mani.
Getting ready to build my log mani.
Its for a ZC (garrett T25).
My questions are:
1.)Is 3/8" (10mm) thick enough for the turbo and exhaust flange?
2.)what internal diameter steam elbows and t's must I use and what wall thickness?
3.) Using a stick welder, what thickness rods are best? 1.5mm, 2mm, 2.5mm, 3mm (Sorry about the metric, but I stay in South Africa).
4.) I'm getting the flanges cut for me, whats the cheapest way to do this? Plasma, laser, waterjet, torch?
Sorry bout all the questions, just don't want to mess this up!
I'm planning to get the faces surfaced after the welding. (good idea? )
Thanks in advance.
Old Mar 31, 2005 | 05:14 PM
SpeedDreamz.com's Avatar
Default Re: Building a log mani. (FranknStein)
3/8 will be ok for a small turbo. The cheapest cut flange will be cnc plasma or laser.
Old Mar 31, 2005 | 07:07 PM
5STAR3's Avatar
Default Re: Building a log mani. (SpeedDreamz.com)
i dont know how much shipping will kill you, but you should oreder your flanges from e-bay or a sponsor on here. that might actually be cheaper than if you had only one made at a machine shop.....
Old Mar 31, 2005 | 09:44 PM
Default Re: Building a log mani. (envision2teg)
that helps a lot thanks! One more question though, I see that they're stainless steel according to that diagram, I was under the impression that it was a cast mild steel fitting? Does it have to be a stainless steel fitting? Also, what welding rods would be a good match so I dont burn holes like I always do?
Old Apr 1, 2005 | 05:22 AM
beepy's Avatar
You can get them in stainless or mild, and you can get the flanges in stainless or mild. Just depends what you want. IMO metal this thick doesn't need to be stainless, it won't corrode through.
Are you going to stick weld it? Just use regular mild steel sticks. You are not going to burn through schedule 40.
Old Apr 1, 2005 | 02:41 PM
AceRaceParts's Avatar
Default Re: Building a log mani. (beepy)
If cost is a concern I would go with the stainless fittings. As strange as it sounds, stainless fittings are actually cheaper than carbon (mild) steel, at this time.
Old Apr 1, 2005 | 04:20 PM
turbo gli's Avatar
Default Re: Building a log mani. (mbpwrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbpwrx &raquo;</TD></TR><TR><TD CLASS="quote">If cost is a concern I would go with the stainless fittings. As strange as it sounds, stainless fittings are actually cheaper than carbon (mild) steel, at this time.</TD></TR></TABLE>
order from this man .. great service and fast shipping .. cheaper then mcmaster too
Old Apr 1, 2005 | 06:51 PM
foursquarepunk04's Avatar
if you always burn holes i might think about taking it to a welding shop. or having someone with expirence weld it out
velisma
Mar 8, 2011 11:25 AM
jfruauff
May 3, 2007 10:11 AM
InterCooL
Welding / Fabrication
Jun 19, 2006 12:11 AM
egizzle8
Jan 29, 2005 11:31 AM
SuperRex
Jul 5, 2004 08:14 AM
