taillight question
well what i did is just cut a hole and pulled it out with some pliers then sealed it back up with some caulk....some people use a dremel to cut the reflector and use a soldering iron to melt it into pieces and then pull them out with pliers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord »</TD></TR><TR><TD CLASS="quote">well what i did is just cut a hole and pulled it out with some pliers then sealed it back up with some caulk....some people use a dremel to cut the reflector and use a soldering iron to melt it into pieces and then pull them out with pliers.</TD></TR></TABLE>
Sounds dangerous, ****.
I can do them locally in So cal or have them shipped out to you.
I dont use baking, solder, or cutting a huge hole at all.
You can see my work on superhonda.com if you want a preview of it and i've been on there quite a while too.
*EDIT* I can do 94-02 Accords too.
