DIFFERENCE BETWEEN PEAK AND HOLD AND SATURATED INJECTORS
Old Mar 30, 2005 | 06:38 PM
k00lt1nt's Avatar
Default DIFFERENCE BETWEEN PEAK AND HOLD AND SATURATED INJECTORS
SO whats the DIFFERENCE BETWEEN PEAK AND HOLD AND SATURATED INJECTORS??
advantage or disadvantage??
which is preferable??
Old Mar 30, 2005 | 07:00 PM
Runnerdown's Avatar
peak and hold are the ones that need the resistor box and are said to be a bit more responsive. saturated are more common, used in all 92 up honda/acura.
Old Apr 22, 2005 | 02:27 PM
AL ASPIRATED's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">peak and hold are the ones that need the resistor box and are said to be a bit more responsive. saturated are more common, used in all 92 up honda/acura.</TD></TR></TABLE>
so peak and hold would be ideal? what if u used a peak and hold injector without a resistor box? STUPID QUESTION, but what would happen?
Old Apr 22, 2005 | 07:19 PM
Runnerdown's Avatar
http://www.hondata.com/techlowohminjectors.html
Old Apr 22, 2005 | 08:25 PM
UncleD's Avatar
S
E
A
R
C
H
Old Apr 22, 2005 | 09:04 PM
rjay8604's Avatar
Default Re: (clean rice)
You use peak and hold's without a resistor box, and you watch your ECU fry.
It will overheat severely and self destruct. No resistance = more current = more heat = fried.
Old Apr 22, 2005 | 09:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">S
E
A
R
C
H
This is a thread that has already been started, so i asked a question here.
sirtef9
Mar 9, 2014 09:00 PM
SFlCrx
Mar 21, 2007 05:48 PM
Dunc
Nov 10, 2006 10:02 AM
Adam West
Dec 9, 2005 07:16 AM
sPaRk'iT
Oct 22, 2003 12:45 PM
