Anti-Freeze draining, wheres the bolt?
Old Mar 30, 2005 | 05:34 PM
dlszrfn's Avatar
Default Anti-Freeze draining, wheres the bolt?
I would assume you just take the bolt off, drain it, put the bolt back in and then fill it up.
But where is this bolt?
Old Mar 30, 2005 | 06:20 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Anti-Freeze draining, wheres the bolt? (dlszrfn)
on the passenger side,right above the bottom corner...
Old Mar 30, 2005 | 06:38 PM
Okthatsdumb's Avatar
its not a bolt, its a little plastic plug. it unscrews like a bolt... and it is exactly where he said it was^^^
Old Mar 30, 2005 | 07:59 PM
XrcR6's Avatar
^^^ Ditto and its technically called a petcock. That is of course, if you want to drain just the radiator contents. If you want to make sure you get at the stuff in the block's water jacket, there is a bolt behind the exhaust manifold on the block. I used this when I did a complete flush.
You probably should get a Helms, it will show you how to refill without trapping air in the cooling system.
Old Mar 30, 2005 | 08:01 PM
CRX-RX's Avatar
Default Re: (XrcR6)
For a full drain, it's a 19mm hex capped plug under the exhuast manifold on the pass side of the motor.
kaivorth
Honda Civic (2001 - 2005)
Oct 31, 2016 04:48 AM
doom26464
Jun 18, 2008 07:10 PM
ehonda1980
Aug 1, 2007 12:18 AM
