Oil feed line...yes I did a search
Old Jan 26, 2002 | 10:55 PM
SlowB16's Avatar
Default Oil feed line...yes I did a search
I was reading the post about tapping into the oil pressure switch line...the one that sends oil into the turbo. And it sounds really complicated.....is it really that hard?? I also looked at Dustin's website to see what he did, and it didnt look all that bad there, but then people are talking about tapping into the block and other stuff. So how hard and complicated is it really to do. I did do a search for this, but I couldnt find an answer to my question
Old Jan 26, 2002 | 11:37 PM
turbopimp's Avatar
Default Re: Oil feed line...yes I did a search (SlowB16)
It's really no big deal to tap the oil feed line...just be careful to thread any adapters that go into the block carefully and STRAIGHTLY. Don't want to cross thread. Some people feel the need to do elaborate setups or are concerned about the BSP vs. NPT pipe threads, but most just use NPT without any problems...
Old Jan 26, 2002 | 11:39 PM
turbocoupe's Avatar
Default Re: Oil feed line...yes I did a search (turbopimp)
Yea. . .make sure it's strait!!! Cross threading-- It's really not that hard.
Old Jan 26, 2002 | 11:45 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Oil feed line...yes I did a search (turbocoupe)
To answer you question, its not that hard. Just takes patients.
Old Jan 27, 2002 | 10:48 AM
SlowB16's Avatar
Default Re: Oil feed line...yes I did a search (Arturbo)
Thanks alot
Old Jan 27, 2002 | 10:56 AM
SiR Kid's Avatar
New User
Bad news is that those 5 parts from a reputable source will end up costing $100
Damn those high pressure fittings Monopolies!!!
[Modified by SiR Kid, 1:56 PM 1/27/2002]
Old Jan 27, 2002 | 03:04 PM
Xerxes's Avatar
New User
Default Re: Oil feed line...yes I did a search (SiR Kid)
where should i go to buy high quality versions of (b) and (d) ?
Z10 makes a part for (b) right? what about the rest? I looked on anplumbing.com and couldn't find any BSP adapters.
-Xerxes
[Modified by Xerxes, 7:48 AM 1/28/2002]
Old Jan 27, 2002 | 03:07 PM
SlowB16's Avatar
Default Re: Oil feed line...yes I did a search (Xerxes)
So I need parts b,c, and d. Correct? Anything else?
Old Jan 27, 2002 | 03:46 PM
cyan1de's Avatar
in response to that diagram arturbo, where is the oil feed line for the turbo? assuming you have one line going to the gauge, the other to the oil pressure switch. would you just buy a tee with another outlet?
Old Jan 27, 2002 | 04:16 PM
BoostInEX's Avatar
hey what website was this? send me the link por favor
Old Jan 28, 2002 | 12:00 AM
intekragsr's Avatar
Default Re: Oil feed line...yes I did a search (BoostInEX)
where is that little hole in the block????????????????? i havent gotten to that part of the install yet and now im scared to death. did all those parts come with my drag kit? as I recall i dont remember some of those/
Old Jan 28, 2002 | 11:24 AM
Xerxes's Avatar
New User
Default Re: Oil feed line...yes I did a search (cyan1de)
Yeah, just get another tee, or a 4-way if they make one (??)
anyone know where i can get that 1/8 NPT (M) -> 1/8 BSPT (F) adapter? i couldn't find it on anplumbing.com ...
-Xerxes
Old Jan 28, 2002 | 12:11 PM
therealciviczc's Avatar
The hole is near the top of the filter with only one wire going in to a rubber boot. Pull the boot off and there is the sending until.
The BPT vs. NPT is a bigger deal to me. They are noticably different. You can't really thread NPT in to BPT without cutting new threads. You might as well be cross threading it.
You can buy the BPT to NPT adapters at AutoZone parts stores made by sunpro for something like $3.00 or $5.00 for a whole pack of useless ones, and the one you need. It's worth it to get it done right IMO. It threads in very very easily.
I think I got all of my fittings and everything needed (besides the turbo feed line) for about $35.00 - $40.00.
[Modified by therealciviczc, 9:12 PM 1/28/2002]
Old Jan 28, 2002 | 12:23 PM
WOTTEG's Avatar
nice Graphic. I made it.
You can get any and all adapters you need from Maryland Metrics.
800-638-1830
Karl
Old Jan 28, 2002 | 01:46 PM
Etylorcen's Avatar
Default Re: Oil feed line...yes I did a search (WOTTEG)
Here is a good pic straight from dustin's shots. http://rely.net/~dustin/images/turbo...l/IMG_0688.JPG Btw its much much much much much easier w/ the filter off.
Old Aug 3, 2004 | 09:24 AM
Curtis2kul's Avatar
Default Re: Oil feed line...yes I did a search (Etylorcen)
ok, so if i got a oil line kit from somewhere and i took the oil pressure switch off so i could put the feed line in where would the oil pressure switch go to, would it just be hanging there or do the kits come with a T of somekind
Old Aug 3, 2004 | 09:25 AM
DaX's Avatar
DaX
Loved
Community Favorite
You should have a tee.
Old Aug 3, 2004 | 09:51 AM
B18EG6's Avatar
Default Re: Oil feed line...yes I did a search (Curtis2kul)
its no big deal if it hangs there, you wont throw any check engine lights or anything.
if you want to keep the oil pressure sensor, either:
1.) tee(s) on the block to allow both oil pressure sensor and oil feed line to attach.
2.) run a line to the firewall, and put the tee there. Check my signature
Old Aug 3, 2004 | 06:39 PM
Curtis2kul's Avatar
Default Re: Oil feed line...yes I did a search (B18EG6)
Thanks
Old Aug 4, 2004 | 06:34 AM
m R g S r's Avatar
I just run an oil pressure gauge, because it will tell you of any problems a hell of a lot faster than the stock oil pressure sensor. Here is a pic of How I have my Fast-turbo.com oil feed. The plugged port on top is for the oil feed line for the soon to be turbo
Old Aug 4, 2004 | 11:44 AM
ITRpwrdEG's Avatar
Default Re: Oil feed line...yes I did a search (m R g S r)
Yuck.
Autozone must have been running a sale on those JDM Frams. Saaaweeet.
Old Aug 4, 2004 | 12:40 PM
G
sh!t happens.
Default Re: Oil feed line...yes I did a search (ITRpwrdEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">I just run an oil pressure gauge, because it will tell you of any problems a hell of a lot faster than the stock oil pressure sensor. Here is a pic of How I have my Fast-turbo.com oil feed. The plugged port on top is for the oil feed line for the soon to be turbo
damn i will never use that autometer plastic hose for oil pressure gauge again...
have you had problems with it yet?
Old Aug 4, 2004 | 12:46 PM
DC_andrew's Avatar
So what do you do with the stock oil pressure sender once its not connected anymore...just kinda leave it there? Will the oil light be on all the time if its not connected?
Old Aug 4, 2004 | 01:00 PM
AL ASPIRATED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowB16 &raquo;</TD></TR><TR><TD CLASS="quote">I was reading the post about tapping into the oil pressure switch line...the one that sends oil into the turbo. And it sounds really complicated.....is it really that hard?? I also looked at Dustin's website to see what he did, and it didnt look all that bad there, but then people are talking about tapping into the block and other stuff. So how hard and complicated is it really to do. I did do a search for this, but I couldnt find an answer to my question</TD></TR></TABLE>
http://www.fast-turbo.com/oilfeedassembly.html
This should answer all questions
and wow this thread is over 2 1/2 years old.
yet still very informative
Old Aug 4, 2004 | 01:01 PM
jmagner's Avatar
Default Re: (DC_andrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_andrew &raquo;</TD></TR><TR><TD CLASS="quote">So what do you do with the stock oil pressure sender once its not connected anymore...just kinda leave it there? Will the oil light be on all the time if its not connected?</TD></TR></TABLE>
yes you leave it there nope it won't make the oil light come on.
or you can use a T and connect the stock sensor + sending unit
vtec4max
May 23, 2007 11:13 AM
stockgreencivic
Apr 11, 2003 01:52 AM
io_burn
Nov 23, 2002 02:32 AM
GruvyTune
Nov 26, 2001 09:55 PM
