p28 code 9/16 and safe mode?? help please.
Old Mar 30, 2005 | 03:38 PM
RicedREX's Avatar
Default p28 code 9/16 and safe mode?? help please.
k ive got a really long story about my d16z6 swap. To break it down, I had a fuel delivery problem, it was flooding the engine with fuel. the p28 was throwing a code 9 and 16, 9 being cylinder 1 misfire or sumtin and 16 was a fuel injection delvery. well that made sense. We narrowed it down to the distributor and changed and the problem was gone, but it still continues to throw the same codes and the cars running in safe mode, so like ****,. There is continuity in all the fuel wiring. I am using an obd0-1 conversion harness with a plug n play harness, vehicle is a 90 crx dx, any thoughts?
car basically runs and idles fine, its just running in safe mode so thers ZERO performance
Old Mar 30, 2005 | 03:45 PM
RicedREX's Avatar
brand new dizzy too.
Old Mar 30, 2005 | 05:35 PM
RicedREX's Avatar
need help.
Old Mar 30, 2005 | 06:06 PM
RicedREX's Avatar
I need suggestions within the next 12 hours!
Old Mar 30, 2005 | 07:09 PM
RicedREX's Avatar
c'mon
Old Mar 30, 2005 | 07:14 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (RicedREX)
well, my post might only serve as a free bump, but did you remove power to the ecu for like 30 seconds to reset it after you put the new distributor on? that was my first thought. but as for where to go from there. ive got nothing. good luck.
Old Mar 30, 2005 | 07:39 PM
RicedREX's Avatar
yea pulled the fuse and the batt. cable, same codes.
Old Mar 30, 2005 | 07:43 PM
RicedREX's Avatar
there were about 3-4 cuts where someone tried splicing into before, they are fuel injector wires going into my odb0-1 conversion harness, theyve been conected with some generic wire and taped up...but they have continuity....would unplugging the ecu do anything?
Old Mar 30, 2005 | 08:00 PM
sanimalp's Avatar
$cat /dev/urandom
i would deffinetly try the ecu unplug, just to make sure that your computer reset. if that doesnt work though, injectors are where i would look to next. the code 9 should have been fixed by the distributor if the wiring is all correct. so a code 16 is injectors.. i would take a close listen to see if they are clicking.. if there is one that isnt, that might be the culprit. you can also test the resistance of your injectors to see if one or more is bad. good luck
Old Mar 30, 2005 | 08:32 PM
RicedREX's Avatar
and btw, if the car runs ins afe mode, itl still should run normal up to limiter right?
Old Mar 30, 2005 | 08:53 PM
doublethink's Avatar
fully unplug the ecu for 10 mintues.
see if that resets it. if not perhaps you still do have a wiring issue.
just gotta hope that ecu is ok, pretty much.
Old Mar 30, 2005 | 08:56 PM
RicedREX's Avatar
wouldnt I get an ecu code if it was bad...
Old Mar 30, 2005 | 10:06 PM
sanimalp's Avatar
$cat /dev/urandom
if the ecu was bad, the light would just be solid lit. wouldnt blink or anything. atleast that is what is supposed to happen. but it never hurts to try another p28 if youve got one handy.
Old Mar 31, 2005 | 07:14 AM
RicedREX's Avatar
I dont have an extra, and springfield IL isnt a honda heaven...im gonna redo some of the cuts and unplug the ecu right now see if anything works.
Old Mar 31, 2005 | 07:47 AM
deftones0817's Avatar
you could have left the wiring in obd0 when you converted to mpfi. I say your error is in the wiring?
Old Mar 31, 2005 | 07:54 AM
RicedREX's Avatar
wiring is all plug and play, its an obd0-1 conversion harness and a compelte engine harness....not saying that isnt casue for error but im gonna check those few cuts real quick.
Old Mar 31, 2005 | 10:57 AM
sanimalp's Avatar
$cat /dev/urandom
make sure all your pins are securly seated on your contacts.. if you had any plugs that gave you problems going together, you might have had a pin or 2 pop out of the harness.
Old Mar 31, 2005 | 08:55 PM
RicedREX's Avatar
same problem started again, fuel overflooding and the same codes, this ****** rediculous.
Old Mar 31, 2005 | 10:06 PM
thenick's Avatar
If you're using a chipped ECU switch out the chips OR make sure it's secure in its place.
Old Apr 1, 2005 | 09:42 AM
RicedREX's Avatar
no chips here.
ghosthatch
May 1, 2014 05:57 PM
ghosthatch
22
May 1, 2014 02:20 PM
Elevorett
Mar 15, 2006 05:27 PM
vtecmike1
Feb 5, 2004 08:27 PM
vtecmike1
Feb 3, 2004 09:15 PM
