16x7 Wheel what offset (+40 or +42) and what size tire should I get?
Old Mar 30, 2005 | 03:22 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default 16x7 Wheel what offset (+40 or +42) and what size tire should I get?
I am planning on getting a set of wheels in 16x7. What offset should I get? Should I get +40 or +42? My DC is lowered @ 2.25" and I dont want to experience any rubbing. Also for a 7" width wheel what width tire is ideal? Should I go with a 205, 215 or a 225? Thanks for your help
Old Mar 30, 2005 | 03:24 PM
gsrious's Avatar
Default Re: 16x7 Wheel what offset (+40 or +42) and what size tire should I get? (FrostyDC4)
keep offset at 40...go with the 205/40/16...
that will ensure no rubbing
Old Mar 30, 2005 | 03:25 PM
PLAGUED_DB7's Avatar
I am not that dropped and running 205 40zr 16's..
here is a pic..no rubbing at all...
Old Mar 30, 2005 | 03:26 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: 16x7 Wheel what offset (red dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">keep offset at 40...go with the 205/40/16...
that will ensure no rubbing</TD></TR></TABLE>
Ah I see. Do you think I will rub with a 215?
Old Mar 30, 2005 | 03:34 PM
BuyImports2's Avatar
the only way to tell if it will rub is put it on and see if it does. also, 215's are more expensive and harder to find. if you get the 205's, get 205/45/16, not 205/40/16. the 40's are smaller than stock and your spedo will be off
Old Mar 30, 2005 | 03:41 PM
gsrious's Avatar
Default Re: (BuyImports2)
dont worry about the 205/40/16, they are the best...the 205/45/16 will be too tall and cause rubbing if your car is too low. the 215 seriers will be way to wide for a lowered teg and if you have camber wear...it will be a tire eater.
Old Mar 30, 2005 | 04:09 PM
Default Re: (red dc2)
how can you assume the 205/40/16 are they best? they aren't even stock size. they will affect your gearing, and your spedo will say that you are going faster than you are. 205/40/16 should be used if and only if 205/45/16 will not fit on your car without problems
Old Mar 30, 2005 | 04:43 PM
95_GSmokeR's Avatar
you know folks, honda-tech isn't the only site with a search engine to give you useful information. i took two seconds out of my precious time to type in "tire size calculator" on google. i found 106,000 answers in .08 seconds, this being one of the useful ones:
http://www.1010tires.com/TireS...ubmit
i like that one because you can plug and play different combinations and get EXACT read outs, including how much your speedo will be off, and in which direction.
when people say "SEARCH!", you gotta remember to try more than one resource (not just H-T). seriously, it took me two seconds. Good Luck
Old Mar 30, 2005 | 05:31 PM
gsrious's Avatar
Default Re: (95_GSmokeR)
when you drive...speedo isn't all that comes into play...if you memorize your rpm, then use that to calculate your speed.
205/40/16 is the best fit tire for your teg if it is lower than about 2 in.
205/45/16 will cause minor rubbing if your fenders are not rolled and your car is lowered about 2 in.
215 will just rub period, if your teg is lowered at about 1.5 in.
these are all based upon stock fenders.
if you are worried about correct speed than my advice is to not cahnge your tire size at all.
Old Mar 30, 2005 | 07:10 PM
iH8RICERZ's Avatar
205/45/16 with a 2.25"ish drop..rims are 16x7 +40 offset...my car was a little bit lower before, and when i hit big dips on the hwy, it did rub on the fender linder..as for doing U turns, it rubs a little but nothing crazy.
Old Mar 30, 2005 | 08:22 PM
SMZ GSR's Avatar
Default Re: (iH8RICERZ)
Pics of my old GSR with 16x7 (i think 45 offset) with 205/45/16, lowered about 2.25-2.5" No rubbing on bumps or U-turns.
Old Mar 30, 2005 | 08:44 PM
if your tire size is off, so will be your rpm's. so using your rpm's to determine your speed is pointless.
Old Mar 30, 2005 | 09:29 PM
gsrious's Avatar
why would rpm be off...rpm is only revolution per min. of the motor...
motor spining and tranny spining are different cases...and besides...like i said if you are scared of your speedo being off...just leave your tire size and rims the way they are, crybabies.
Old Mar 30, 2005 | 09:56 PM
trutuner's Avatar
how much you looking to spend thats the issue i think?&gt;....-Roger
Old Mar 31, 2005 | 07:23 AM
rusteds2k's Avatar
205/40/16 will fit nicely, but it will ride like ****.
I just replaced my 40series to 45 and it still fit nicely and it rides 100% smoother.
Old Mar 31, 2005 | 07:35 AM
when i say that the rpm will be off, i mean that with the different tire sizes, the same engine rpm in the same gear will yield different actual speeds. the tach will still reflect the actual engine rpm. sorry about the confusion
Old Mar 31, 2005 | 09:10 AM
JDMHN8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">215 will just rub period, if your teg is lowered at about 1.5 in.</TD></TR></TABLE>
My car is about 2" lower than stock with 215/45/16 Azenis and has NEVER rubbed on anything, ever. Why don't you make up some more stupid ****. ******* idiot.
Old Mar 31, 2005 | 09:26 AM
gsrious's Avatar
Default Re: (JDMDA9)
**** off...i am entittled to my opinion...damn a--hole
Old Mar 31, 2005 | 09:40 AM
yangrou8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 &raquo;</TD></TR><TR><TD CLASS="quote">My car is about 2" lower than stock with 215/45/16 Azenis and has NEVER rubbed on anything, ever. Why don't you make up some more stupid ****. ******* idiot. </TD></TR></TABLE>
agreed. i am lowered 2 in as well on 205/45/16 and have never ever had rubbing. i had 205/40 for a while and it rode horribly and didnt offer enough protection for my rims (i bent forged rims). seeing youre from ny (lots of potholes), go with the 45 series with a 40 offset and 7in rim.
btw, check this out for stock sizes: http://www.whalentire.com/tire...=8298
Old Mar 31, 2005 | 09:42 AM
m R g S r's Avatar
https://honda-tech.com/zerothread?id=1152210
Old Mar 31, 2005 | 09:55 AM
JDMHN8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">**** off...i am entittled to my opinion...damn a--hole</TD></TR></TABLE>
OK, you didn't post an opinion. You tried to pass off your immense "knowledge" as fact. Not gonna work, ********...
Old Mar 31, 2005 | 10:04 AM
riceball777's Avatar
do not get 205 40 16 then are way smaller than stock and lt looks stupid
the correct size for an integra is 205 45 16
Old Mar 31, 2005 | 10:22 AM
i agree. red dc2 is a douche
Old Mar 31, 2005 | 04:59 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Looks like I'll be getting a 16X7" wheel w/a +40 offset and 205 width tire. However I have another dilema . The tires that I want (the Bridgestone Potenza S-03's) only come with in a 50 or a 55 series depth . Do you think I will rub with either ? I really want to give the RE050A's a try but they will rub for sure (225 width wheel ). Do you guys know of a tire that will provide performance (hot, cold, and wet weather) similar to or greater than the S-03's? Thanks!
Old Mar 31, 2005 | 05:31 PM
JDMHN8's Avatar
Default Re: (FrostyDC4)
I run 205/50/16s on my Enkei "Rally" wheels for street use and have NEVER rubbed. The sidewalls are kind of big (but not stupid looking as some will try to make you believe), but it's still an acceptable size. 55 series is out of the question though, unless you want to look like an idiot...
