ecu jumper cable
Old Mar 30, 2005 | 02:53 PM
H22A EG6's Avatar
Default ecu jumper cable
i need to know where it is my car wont reve past 3500 rpm and it is on and off running on 2 cyl and then all 4 and back again it is a 1992 GS
Old Mar 30, 2005 | 02:56 PM
Racermech's Avatar
Default Re: ecu jumper cable (H22A EG6)
What engine, what ecu,what mods, any CEL codes, if so what are they.
Old Mar 30, 2005 | 02:58 PM
H22A EG6's Avatar
Default Re: ecu jumper cable (Racermech)
i am asking where the jumper cable is so i can check the ecu codes
it is a GS so B18A no mods daily driver
Old Mar 30, 2005 | 03:38 PM
H22A EG6's Avatar
found the jumper but it gives me no code! it there somthing different with an OBD0 ecu??
what can i do
Old Mar 30, 2005 | 03:48 PM
SYTFU Tommy.'s Avatar
just pull out the 10amp fuse under the hood. turn the key to on. look at the ecu for the code. long means 10 short meams 1. so its like _ _ _ _ ---- which means like 44. just and example
Old Mar 30, 2005 | 05:42 PM
H22A EG6's Avatar
Default Re: ecu jumper cable (tngay)
really! i have never done an OBD0 before ill check it out thx
but which 10 amp fuse
Old Mar 31, 2005 | 07:19 PM
H22A EG6's Avatar
found it, wtf 10 amp fuse???
edro13
Nov 20, 2009 03:05 AM
98GSRrdr
Mar 20, 2007 11:17 AM
BLACK_DEL_SOL
Jan 3, 2005 01:43 PM
dj626
Sep 27, 2004 03:31 PM
Count Blah
19
May 26, 2003 04:43 PM
