buddy club cam gear timing??
i posted this in the tech forum but no luck so ill try here...
my friend and i put on my buddy club spec 3 cams/cam gears tonight and the valves would hit the pistons after we did the timing? the marks on the buddy club gears are not right.....i put on the stock cam gears and the problem went away..does anybody have a diagram on how to do the timing for there cam gears???thanks
Make sure the Buddy Club logo is at the top when locating tdc. Also they should have marks on them. The exhaust cam gear will have a mark at 3 o'clock and the intake cam gear will have a mark at 9 o'clock. Line those marks together for tdc as well. Also make sure that you don't have them extremely retarded or advanced, for example, like 12 degrees. That should help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_Del Sol »</TD></TR><TR><TD CLASS="quote">lucky..</TD></TR></TABLE>
Was this a Napolean Dynamite reference?
In all seriousness, take your time, take a deep breath and do it again til you get it right. The benefits of adj. cam gears are tremendous if you ever plan on getting your vehicle on a dyno.
No other info that you NEED. Just take your time and make sure all your marks are lined up. Its not rocket science, just car science.
Also, just out of curiousit, the buddy club cam gears are zero'ed out, correct? And by that i mean set on '0', no advance, no retard?
there is no dimples on the buddyclub cam gears...that's the problem!!
i'll even take a picture right now and show it to you...
Modified by slayersluck at 12:49 AM 4/5/2005
i'll even take a picture right now and show it to you...Modified by slayersluck at 12:49 AM 4/5/2005
yeah post pics because to me it looks like i have 2 of the same cam gears or something its weird ****...i emailed buddy club and they said to call them so i will.....now the bitch wont start after the install....not sure if its the timing or fuel.....my dad is working on it to fix it now because i am done with spring break and im away....hopefully he can figure it out
what i did was got a stock cam gear and lined it up with buddy club and put the exact same markings on it...
oh yeah and make sure that adjustable bolts are tight....cuz mines were loose
Ef4doorwagon
13
May 17, 2014 06:09 PM
sbk23
Jun 19, 2010 04:41 PM
but hey...it works
