Throttle body removal
Old Mar 30, 2005 | 01:31 PM
bladesoxy's Avatar
Default Throttle body removal
I've been trying to remove the throttle body off of my '90 integra for some cleaning, but that thing is just fused to the intake manifold. I got all the hoses and nuts disconnected from it already so it's not that it's just plain and simply stuck.
Has anyone had a similar experience and what did you do to get that thing off?
Old Mar 30, 2005 | 01:48 PM
jdm_cars's Avatar
Default Re: Throttle body removal (bladesoxy)
the gasket seals the TB to the manifold, so you just gotta wiggle it and apply some force when pulling it off after you removed the bolts.
Old Mar 30, 2005 | 01:55 PM
AlxSiR7's Avatar
Default Re: Throttle body removal (jdm_cars)
yea.. the gasket is probably just old and has the tb sealed to the manifold pretty tight.. just pull straight out and wiggle it a little.. you'll get it.
Old Mar 30, 2005 | 02:59 PM
bladesoxy's Avatar
Thanks guys. A couple good hits with my rubber mallet did the trick so now that it's off it's time to clean. Thanks again.
Old Mar 30, 2005 | 04:56 PM
AlxSiR7's Avatar
Default Re: (bladesoxy)
should clean your iacv and fitv (obd1) while you're at it
Zanzapod
Welding / Fabrication
Jun 25, 2012 11:58 PM
JDM_EK_JOE
Mar 3, 2012 07:07 PM
Gsrsi
Dec 4, 2011 03:04 AM
averyvm
Oct 2, 2008 06:06 PM
zilverz
Jun 23, 2002 12:58 PM
