Replacing all steel brake and fuel lines
Old Mar 30, 2005 | 12:36 PM
extro97's Avatar
Default Replacing all steel brake and fuel lines
Whats the best, cheapest way to do this? Buy pre-bent, have em bent, bend them myself? The lines are so rusted that if I move one it will break the other. Got leaks all over. This is on a 95 gsr. One CNY winter did this. Ive never bent steel line but Id be willing to try. Assuming I can get the old ones off, just match them ? Come to think of it the fittings are probably shot on the rubber hoses to. A shop gave me a quote of like $400(lying scumbag). Any advice appreciated.
*Anybody selling aftermarket pre-bent lines like in stainless steel for Integra's?
Contact me if your an HT member.
***Thanks for the responses below. The factory prebent are like $80 to $120 a peice. I have to do everything. The lines are rusted into the clips. A good chunk of snow and ice put massive leaks in every one. I have to look closer but the bracket that the lines come into just in front of the tank, cant I just bypass that with new lines going all the way back?
Modified by extro97 at 4:30 PM 3/31/2005
Old Mar 30, 2005 | 12:42 PM
Racermech's Avatar
Default Re: Replacing all steel brake and fuel lines (extro97)
You can get a tube bender. A lot of hot dor guys have to do custom tubes, so the just bend them all my hard with the little tube bender.
I would check out summit racing, or some other hot rod places.
Old Mar 31, 2005 | 04:34 AM
drumking15's Avatar
I just bent all new lines from my MC to prop valve to front 2 lines...bending them by hand is the best way...then again my motor was out of the car and i had all the space to work on it...but i just bought lines from my auto parts store...and got roughly the right lengths...and fit those bad larrys in there
Old Mar 31, 2005 | 10:24 AM
dwolsten's Avatar
It shouldn't be that hard to do this yourself. Any normal parts store sells all the parts you need: steel hardlines, fittings, and tools. You should be able to rent/borrow the tools from the store. You'll need a tubing bender to make nice bends, and a flaring tool to install the fittings. Note that the brake lines must have the ends double-flared, not single-flared. Do a search on Google for all these terms and you should be able to find some really educational pages.
Old Apr 13, 2005 | 04:20 AM
raider099's Avatar
Default Re: Replacing all steel brake and fuel lines (dwolsten)
anyone have a pic of their finished job?
Old Apr 13, 2005 | 07:34 AM
95lstegman's Avatar
Default Re: Replacing all steel brake and fuel lines (raider099)
go to autozone. you can borrow one, put a deposit on it, and when you bring it back, you get ALL your money back. since you won't be doing this again, no need to buy it. they have a brake tubing bender i believe.
Old Apr 13, 2005 | 08:35 AM
Muckman's Avatar
Moderator in Chief
Your so much better off just buying the OEM prebent lines. Its going to be such a bitch to bend it perfectly to fit. You also need the ends and a tube flarer.
anthonycox28
Dec 11, 2013 06:15 PM
jdmkid8383
Apr 22, 2007 11:34 AM
adam94lude
Oct 20, 2005 01:38 PM
ActiveAero
Aug 3, 2004 07:31 AM
jolt-tsp
20
Sep 2, 2003 10:10 AM
