bigger injectors or more fuel pressure...
Old Mar 30, 2005 | 12:25 PM
ceLtic*
Guest
Posts: n/a
Default bigger injectors or more fuel pressure...
setup:
b18a1 bottom end
PCT's[ctr's] in 20 over
golden eagle ls/vtec kit
BC3+ cams/gears
pr3 head
an-R header
aebs intake manifold
using a fuel pressure regulator, wideband o2, and a vafc for tuning <U>only</U>.
what would you do? upgrade to 340cc injectors or turn up the fuel pressure?
i should be around 190-204 wheel horsepower after tuning..
Modified by ceLtic! at 1:38 PM 3/30/2005
Old Mar 30, 2005 | 12:37 PM
sfwdcivic's Avatar
Default Re: bigger injectors or more fuel pressure... (ceLtic!)
bigger injectors
Old Mar 30, 2005 | 12:39 PM
ceLtic*
Guest
Posts: n/a
Default Re: bigger injectors or more fuel pressure... (jkjb16a)
anyone else?
Old Mar 30, 2005 | 01:14 PM
LSVTEC 91 Civic's Avatar
Banned
OBD1 Prelude injectors work great (340-345cc)... Seems you're running a similar setup to mine. My fuel pressure is at 46psi, with as much as -23% taken out of VAFC at WOT. (Dyno tuned)
Old Mar 30, 2005 | 01:16 PM
spartacus087's Avatar
bigger injectors will make your life much easier and they will leave you much more tuning room for the future. if you can find some cheap ones id say that would be a good move.
Old Mar 30, 2005 | 01:38 PM
ceLtic*
Guest
Posts: n/a
Default Re: bigger injectors or more fuel pressure... (spartacus087)
just bought some 340's
Old Mar 30, 2005 | 02:06 PM
stockmr2's Avatar
how much did the 340 cost and what kind?
Old Mar 30, 2005 | 08:43 PM
ceLtic*
Guest
Posts: n/a
Default Re: bigger injectors or more fuel pressure... (stockmr2)
RC 75/ each
Old Mar 31, 2005 | 01:51 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockmr2 &raquo;</TD></TR><TR><TD CLASS="quote">how much did the 340 cost and what kind?</TD></TR></TABLE>
I got my OBD1 preludes for $80.
Old Mar 31, 2005 | 01:53 AM
ceLtic*
Guest
Posts: n/a
Default Re: bigger injectors or more fuel pressure... (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
I got my OBD1 preludes for $80. </TD></TR></TABLE>
i am obd0
Old Mar 31, 2005 | 01:55 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic! &raquo;</TD></TR><TR><TD CLASS="quote">i am obd0 </TD></TR></TABLE>
Even better, you already have a resistor box wired in...
SpeedRacerEX-R
Jul 29, 2015 08:26 AM
85
Jan 31, 2010 02:46 PM
panchovilla760
Nov 9, 2006 08:19 PM
eg:R
Sep 12, 2006 10:31 AM
red civic standard
Nov 15, 2004 05:34 AM
