***NYS Inspection: how to pass... heres my thought...***
Old Mar 30, 2005 | 11:25 AM
J337_UNIT's Avatar
Default ***NYS Inspection: how to pass... heres my thought...***
UPDATE ON PAGE 2: nothing big, just wanted to inform fellow NY'ers with this problem, that I did in fact pass today with this method.
If you are supposed to be OBD2 but swapped it out for OBD1 , you are in trouble, (i am) as many of you already are aware of this. So how do you pass?
The only way i can think about getting a sticker that will work and is legit is this...
First of all i hope you saved your OBD2 ecu. Because apparently, the ECU stores the vin number in it.
Ok ...
Step 1) Find a shady inspection station, or make a friend who inspects cars.. One of my good friends happens to be an inspector
Step 2) Find someone with a stock integra, civic, whatever car it is that YOU have, find someone with a stock version of it, and make sure its going to share the same ecu as you, (obd2a 96-99) or (obd2b 00-01)...
Step 3) put your ecu into their car
Step 4) go down with the car to the inspection station with YOUR registration also.. Now the inspector will scan YOUR registration. SO the NYS already thinks its your car, then when they run the ecu testing bullshit on the ecu, the failsafe is that its your ecu. So all the info that is on it, is yours such as your vin number.
Step 5) pending you dont have any CEL's saved in your ECU then that portion of the test will pass. Why? because it just did the test on your ecu.. plain and simple.
I have not personally tried this yet. But i will. And my friend who inspects, tells me this will definately work.
If there are any inspectors reading this thread, please post your thoughts about this.
Modified by J337_UNIT at 6:31 PM 7/5/2005
Old Mar 30, 2005 | 11:45 AM
RidinStock's Avatar
Default Re: ***NYS Inspection: how to pass... heres my thought...*** (J337_UNIT)
Sounds Logical, I think... is that all they use to scan for info? I've never dealt w/ OBDII. Bump for getting some more opinions.
Old Mar 30, 2005 | 11:54 AM
J337_UNIT's Avatar
Default Re: ***NYS Inspection: how to pass... heres my thought...*** (RidinStock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinStock &raquo;</TD></TR><TR><TD CLASS="quote">Sounds Logical, I think... is that all they use to scan for info? I've never dealt w/ OBDII. Bump for getting some more opinions.</TD></TR></TABLE>
yea registration and ecu are the only objects they can physically scan. so those 2 objects must be from your car in order to make this work.
Old Mar 30, 2005 | 12:43 PM
Racermech's Avatar
I would suggest change the ecu a couple day ahead of time to make sure everything is running correct
Old Mar 30, 2005 | 02:10 PM
njandrewg's Avatar
ok say you do that...but whats gonna happen when they scrape off the guy's original sticker and put the new one on?
Old Mar 30, 2005 | 02:19 PM
J337_UNIT's Avatar
Default Re: ***NYS Inspection: how to pass... heres my thought...*** (njandrewg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">ok say you do that...but whats gonna happen when they scrape off the guy's original sticker and put the new one on? </TD></TR></TABLE>
as i said before... if u take it to a shady shop, or someone u know... then u dont have to worry about that. hell just give you the sticker and u stick it on your car.
Old Mar 30, 2005 | 02:32 PM
njandrewg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">as i said before... if u take it to a shady shop, or someone u know... then u dont have to worry about that. hell just give you the sticker and u stick it on your car.</TD></TR></TABLE>
yes but ur thread is about using that to get a legit sticker.
Old Mar 30, 2005 | 02:35 PM
numbnuts22715's Avatar
that sounds pretty logical... I just dunno how easily someones going to let you borrow their car...
Other than that sounds pretty good :thumbup"
Old Mar 30, 2005 | 02:36 PM
Tiferet's Avatar
why not keep your car legal, and not worry about it?
Old Mar 30, 2005 | 03:11 PM
J337_UNIT's Avatar
Default Re: (drip pan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drip pan &raquo;</TD></TR><TR><TD CLASS="quote">why not keep your car legal, and not worry about it?</TD></TR></TABLE>
its a pain in the *** to go back to OBD2 at this point for me.. plus being boosted owns..
yes but ur thread is about using that to get a legit sticker.</TD></TR></TABLE>
yea, the sticker is legit... the method going about getting the sticker is not however
Old Mar 30, 2005 | 03:12 PM
J337_UNIT's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">that sounds pretty logical... I just dunno how easily someones going to let you borrow their car...
Other than that sounds pretty good :thumbup"</TD></TR></TABLE>
for some people, this could pose the problem... however i know a few integras around that are stock and one of them is willing to help me. so looks like ive got my *** covered for that part. and also ive got my *** covered for the inspector part.
Old Mar 30, 2005 | 03:31 PM
eag36's Avatar
Default Re: (J337_UNIT)
wouldn't it also be possible to just locate the power wires going to the OBD2 ECU and connect it to the OBD2 reader so when you go in and they plug into the reader it actually reads your OBD2 ECU which isn't actually doing anything and just thinks that the key is turned to the 'run' position? Cuz if it can't read mileage or anything then it will just store whatever it was shut off with.
Old Mar 30, 2005 | 04:11 PM
AznInvasion's Avatar
Default Re: (eag36)
i'm also in NY and i'm tryin to build a 2000 ek with either gsr swap. so that means i need to get a 00-01 gsr ecu which i cant find with the imobolizer in it. Or can i run a 99-01 Si ecu and not have throw a cel?
Modified by AznInvasion at 1:31 AM 3/31/2005
Old Mar 30, 2005 | 06:10 PM
Cliffjumper2's Avatar
If you "know a guy" to get a hookup, then why bother going through all that. There are easier ways to get your obdII teg passed while running an obdI ecu. You don't even need the other car to be a honda, much less a teg.
or so I've heard
Old Mar 31, 2005 | 06:34 AM
Tiferet's Avatar
well, you should have thought about this a little further before modding a street car.
Old Mar 31, 2005 | 07:59 AM
J337_UNIT's Avatar
well at the time, it was ok to swap to obd1, there was no inspection test for this. As of this year, they changed the inspection laws for 96 and up cars. So this is the way around it.
BLacK FirE's Avatar
well, you should have thought about this a little further before modding a street car. </TD></TR></TABLE>
Yes because we are psychics knew that NY was going to pass legislation allowing for stricter emmisions testing.
Old Mar 31, 2005 | 08:02 AM
Tiferet's Avatar
Default Re: (BLacK FirE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE &raquo;</TD></TR><TR><TD CLASS="quote">
Yes because we are psychics knew that NY was going to pass legislation allowing for stricter emmisions testing.</TD></TR></TABLE>
LMAo, thats the risk you have to take.
Old Mar 31, 2005 | 10:38 AM
J337_UNIT's Avatar
LMAo, thats the risk you have to take.</TD></TR></TABLE>
dude your not even from NY , stop throwing you 02 cents in if you have nothing benefiting this thread... thanks
Old Mar 31, 2005 | 11:34 AM
vgsr's Avatar
How about if you did this:
1) Keep your stock obd2 ecu, buy a obd1 edu chip it and run that all the time. Then when inspection comes around, u swap back in the obd2 ecu (i dunno if switching back and forth between ecu's would work if you have a turbo teg or something)
2) What if you have a greddy emanage or something as a piggyback on the obd2 ecu, will that pass inspection?
Old Mar 31, 2005 | 12:18 PM
Tiferet's Avatar
dude your not even from NY , stop throwing you 02 cents in if you have nothing benefiting this thread... thanks</TD></TR></TABLE>
LMAO
Old Mar 31, 2005 | 02:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">well at the time, it was ok to swap to obd1, there was no inspection test for this. As of this year, they changed the inspection laws for 96 and up cars. So this is the way around it. </TD></TR></TABLE>
when did this change in the inspection law/procedure take place?
cause I just had my 97 integra inspected in February, and they inspected it the same way they did my 94 teg last year.
Old Mar 31, 2005 | 03:14 PM
BLacK FirE's Avatar
Default Re: (Cliffjumper2)
Sometime last year the law was passed. All inspection stations have to have the new equipment and performing the new inspections by April 1, 2005.
Old Mar 31, 2005 | 05:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE &raquo;</TD></TR><TR><TD CLASS="quote">Sometime last year the law was passed. All inspection stations have to have the new equipment and performing the new inspections by April 1, 2005. </TD></TR></TABLE>
I see................good to know, thanks
Old Mar 31, 2005 | 07:09 PM
Code Blue's Avatar
that is the best way. hands down, me and a friend in the city talked about it for about an hour, the vin number IS stored in the ecu and the reader DOES scan it and match it to the registration.
an easier thing to do, is just have a copy of your registration sticker, go to the dmv and request a duplicate inspection, and when they go to scan the reg, they can simply scan the sticker, so only one car has to be there.
