Clutch Squeek and resistance at awkward times ??
My clutch squeeks right around when its fully pressed on, about 3 inches to the floor. Also the clutch seems to have resistance going in and out when it is cold, but when it is hot outside it is very smooth and almost effortless to push in.
How are everyone elses clutch (smooth?? some resistance, etc??) ?? If you recommend lubrication, how do I go about doing this ?? Is it a simple lube job with grease ??
Mine is acting kind of weird as well. If I just pump it (full in to full out) i can hear a a sweek as well.
This one is super bizzare... If i am making a left turn with the clutch in, finally when i start to straighten out and let the clutch out it feels like is bumps or air got in the line. Then the next time i shift, it feels like there is an air pocket at the top part of the travel, but pushing it past that point it feels like it pops and it is fine from there on. This only happens with left turns... I have no idea.
Those are my clutch quirks... any thoughts?
xunkn0vvnx
Mar 30, 2005 07:52 AM
