relocating valve cover ground line
Where would be a good place to move the valve cover ground to? Does it have to be attached to the valve cover, or can it be anywhere on the block?
I dont want to totally get rid of it. In my old Teg i had a different ground and I did not crimp down the ends enough, so it would rattle and cause my battery light to flick on and off.
It's best to keep it attached to the valve cover. I personally like to use the spot on the right rear of the valve cover (assuming looking at the car from the front) where the power steering line mounts and then running it a couple of inches to a hole for a 10mm that's maybe three inches away on the shock tower. It comes out looking particularly clean as well.
Regarding grounding you can never have too many, Ideally you would have one each running from each of the following:
valve cover
head
block
tranny
intake mani
throttle body
valve cover
head
block
tranny
intake mani
throttle body
That is where mine is going now. I have anice braided flat ground stap that looks nice. But it still looks bad comming off the front. With my AC lines and PS pump gone the front end will look a lot cleaner
