sohc manifold to y8 manifold questions
Old Mar 30, 2005 | 07:16 AM
racingant's Avatar
Default sohc manifold to y8 manifold questions
Purge Cut Solenoid Valve: Don’t bother with the one from the Y8 fuel rail…sell it on ebay. Just run a vacuum line to the stock A6 solenoid that is mounted on the firewall.
can u tell me where on the firewall a cn find this and where do i get the vacuum line from
I'm also using a gsr tb not my stock tb and on top of the stock tb theres a vacuum that runs to the charcoal canister now on my gsr tb there is no where to put the vacuum that comes from the charcoal canister where do i put the vacuum
i'm using a b18c5 gsr tb can i use the rotor that on the tb or do i have to use the one off my d15b motor
where the purge cut solenoid valve was what goes there now i was looking at the pic and it say that the bashpot goes there what and where is that
now i'm using a gsr tb do i still have to bypass the coolant from th tb and the iacv or do i hook it up with this tb
THANK FOR AL THE HELP
Old Mar 30, 2005 | 08:42 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: sohc manifold to y8 manifold questions (racingant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">can u tell me where on the firewall a cn find this and where do i get the vacuum line from</TD></TR></TABLE>
if you look HERE, under vacuum lines it shows were the p-c-s valve is. look on your vacuum diagram under the hood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">I'm also using a gsr tb not my stock tb and on top of the stock tb theres a vacuum that runs to the charcoal canister now on my gsr tb there is no where to put the vacuum that comes from the charcoal canister where do i put the vacuum</TD></TR></TABLE>
run the existing port on the TB to the charcoal canister which then runs to the purge-cut-soleinoid valve.
either extend your map sensor wiring to plug into the TB(abandon the stock, firewall mounted one) or take out the map sensor on your b18c5 TB and run a vacuum line to your stock map sensor (if possible)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">i'm using a b18c5 gsr tb can i use the rotor that on the tb or do i have to use the one off my d15b motor</TD></TR></TABLE>
the one on the b18c5 tb should be fine. you wont have a dashpot on that setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">where the purge cut solenoid valve was what goes there now i was looking at the pic and it say that the bashpot goes there what and where is that </TD></TR></TABLE>
you wont have a dashpot, just plug the extra vacuum stubouts on the manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">now i'm using a gsr tb do i still have to bypass the coolant from th tb and the iacv or do i hook it up with this tb</TD></TR></TABLE>
you dont have to bypass the coolant at all. just hook it up as from the factory if you'd like.
fireant
Dec 14, 2008 03:56 PM
racingant
Mar 31, 2005 11:13 AM
sleepyhamsterlx
Aug 2, 2004 06:11 PM
scttydb411
Jan 31, 2004 08:59 PM
JCracer723
Jul 29, 2003 10:06 AM
