Suspension & Brakes Theory, alignment, spring rates....
omni power full coilover situation?!?
Old Mar 30, 2005 | 01:27 AM
Mike Mafia's Avatar
Default omni power full coilover situation?!?
So I trashed my **** ractive coilovers and bought the Omni Power full coil over set up. The ride is amazing! Here's the situation..
My back end can drop about a half inch lower then the front and I was told this isn't normal in fact it should be the other way around?!? So i'm confused. The back end is also a lot stiffer than the front?!? Do you guys think you can help me out with this? And yes I pre-loaded the springs, so i'm not to sure what's up...help?? thanks a lot guys
Old Mar 30, 2005 | 04:59 AM
Dirk-EG's Avatar
Default Re: omni power full coilover situation?!? (Mike Mafia)
you can switch over the entire strut if you unscrew the bottom part, my guess is you have them on front<->back.
dont preload too much, just enough not to make them loose without the load on the car.
Old Mar 30, 2005 | 01:05 PM
Mike Mafia's Avatar
Default Re: omni power full coilover situation?!? (Dirk-EG)
SO dont prelaod as much as it tells me to? I didn't think I could take off the bottem part as far as I remember it stops at one point and wont come off?
Old Mar 30, 2005 | 01:15 PM
Dirk-EG's Avatar
I've seen numerous discussions about preload and to my best shuffling of the info i gather it does little more then hold the spring in place while there is no load of the car on it, which is all it really should do, under normal conditions..
And I've seen the bottom ends come off all the way on pictures, so it must be possible.. just the bronze part, mind you. If its screw'able, they must have gotten them on SOMEhow, proces should be reversable..
Old Mar 30, 2005 | 01:48 PM
Mike Mafia's Avatar
From what I gather you want me to switch the bronze ends front to back back to front and that should solve my plm. and pre load them less then I have. I might as well try it. thx anyone else want to help on this it would be great
Old Mar 30, 2005 | 10:14 PM
Dirk-EG's Avatar
The bronze ends cannot be reversed front to back, because they NEED to be installed front & back, they wont physicly fit reverserd! Everything else though, should be swapped over..
*pardon my spelling*
Old Apr 1, 2005 | 03:34 PM
PIC Performance's Avatar
Omnipower's DC2 shock bodies are the same length, front and back.
This is probably the same problem that has been described by several other people, where the rear lower mount is too short, and does not allow enough range of adjustability. Contact Omnipower, they seem to have taken care of previous instances of this problem very well.
edit: See this post:
https://honda-tech.com/zerothread?id=1192191
Old Apr 1, 2005 | 03:52 PM
DriftTheEg's Avatar
Default Re: omni power full coilover situation?!? (Noob4life)
I've heard its common amoung coilovers to do that. I have Yonaka Coilovers and they do the same
Old Apr 2, 2005 | 04:06 PM
Psychedelicone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noob4life &raquo;</TD></TR><TR><TD CLASS="quote">Omnipower's DC2 shock bodies are the same length, front and back.
https://honda-tech.com/zerothread?id=1192191</TD></TR></TABLE>
Yeah I would contact Steve AKA omniman on here via IM that is what I did last weekend and my solution will be here on Tuesday!
Old Apr 2, 2005 | 05:38 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: omni power full coilover situation?!? (Psychedelicone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Psychedelicone &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I would contact Steve AKA omniman on here via IM that is what I did last weekend and my solution will be here on Tuesday! </TD></TR></TABLE>
Actually, you should email him. He doesn't log on to H-T all that often.
Old Apr 2, 2005 | 07:18 PM
Default Re: omni power full coilover situation?!? (rochesterricer)
Yeah that maybe true but I IM'd him last Sat. night and had a reply on Easter Sunday. But do what ever you like he does check the AOL address in his profile!
Old Apr 3, 2005 | 01:24 AM
Mike Mafia's Avatar
When I e-mail/i-m him what exactly should I say to him so everything is all clear? Thanks so much for your posts
Old Apr 3, 2005 | 06:43 AM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirk-EG &raquo;</TD></TR><TR><TD CLASS="quote">dont preload too much, just enough not to make them loose without the load on the car.</TD></TR></TABLE>
iam sorry..could you tell me more about "dont preload too much". how do i do that? i dont even know basic preload tech *i know what preload is just dont know how*
Old Apr 3, 2005 | 07:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike Mafia &raquo;</TD></TR><TR><TD CLASS="quote">When I e-mail/i-m him what exactly should I say to him so everything is all clear? Thanks so much for your posts </TD></TR></TABLE>
Sent you an IM.
Old Apr 3, 2005 | 12:50 PM
Mike Mafia's Avatar
Sent you an IM.</TD></TR></TABLE> alright i'm going to get in contact with him now i'll let ya know how it goes
Old Apr 3, 2005 | 07:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike Mafia &raquo;</TD></TR><TR><TD CLASS="quote"> alright i'm going to get in contact with him now i'll let ya know how it goes </TD></TR></TABLE>
Cool I am sure Omniman will get it worked out!
Old Apr 3, 2005 | 11:16 PM
Dirk-EG's Avatar
Many topics on pre-load, look it up..
power11
Suspension & Brakes
12
Jul 15, 2007 11:50 AM
NeWnMpR0VeD
Suspension & Brakes
Jan 23, 2006 10:12 AM
LaOstha
Suspension & Brakes
Aug 5, 2005 09:13 AM
ABK
Mar 8, 2005 05:22 PM
deviant1
18
Nov 14, 2003 10:31 AM
