Where do these plugs go(dash wiring)
Old Mar 29, 2005 | 11:00 PM
Timmay's Avatar
Default Where do these plugs go(dash wiring)
fixing **** behind my dash today, found a few unused plugs
behind gauge cluster, maybe a ground?
this was on the floor behind the center console, below the heater area
any ideas?
UPDATE:
hooked up the heater hoses to the motor, and still no heat, just blows cold air, this is getting frustrating
Modified by Timmay at 1:25 PM 3/31/2005
Old Mar 29, 2005 | 11:49 PM
Timmay's Avatar
Default Re: Where do these plugs go(dash wiring) (Timmay)
oh and everything buy my cruise control works
Old Mar 30, 2005 | 07:51 AM
Timmay's Avatar
bump before work
Old Mar 30, 2005 | 08:54 AM
fast2camciv's Avatar
the top one looks definetly like a ground of some sort but what?
the bottom one almost looks like the plug for the stereo? and then maybe the cigarette lighter for the small one?
Old Mar 30, 2005 | 04:41 PM
Timmay's Avatar
Default Re: (fast2camciv)
both stereo and cigarette lighter are already plugged in
Old Mar 30, 2005 | 04:47 PM
Pete_SI's Avatar
Default Re: (Timmay)
The top one is a ground...if you look closely enough their is a plus to hook up to....But as long it's grounded.
teknojiz's Avatar
Hatchback Maniac
The first plug is a ground wire. It plugs onto a metal clip behind the cluster. I think it's on the steering column support.
Old Mar 30, 2005 | 04:55 PM
dfoxengr's Avatar
if you didnt unplug them then dont worry about it.
Old Mar 30, 2005 | 04:58 PM
Timmay's Avatar
Default Re: Where do these plugs go(dash wiring) (hybridvteceg)
well does the floor part of the heater have its own wiring? cause i dont get air when i put it on floor
im sure that ground is needed?
Old Mar 30, 2005 | 06:13 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Probably easier to let everyone know which ones you do have plugged in.
Old Mar 30, 2005 | 06:58 PM
f1z1c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">well does the floor part of the heater have its own wiring? cause i dont get air when i put it on floor
im sure that ground is needed?</TD></TR></TABLE>
Theres going to be wiring going to the blower. Is something not working as it was, like your heater fan?
Old Mar 30, 2005 | 07:12 PM
Timmay's Avatar
Default Re: Where do these plugs go(dash wiring) (f1z1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1z1c &raquo;</TD></TR><TR><TD CLASS="quote">Theres going to be wiring going to the blower. Is something not working as it was, like your heater fan?</TD></TR></TABLE>
well my fan works on defrost, and vents but no floor action
i have no clue where the big plug goes, there is nothing around there for it to plug into
Old Mar 30, 2005 | 07:20 PM
Emshhh's Avatar
the bottom looks like the "service connector" to check CEL codes and diagnostics.
that's my guess
Old Mar 30, 2005 | 07:26 PM
Cray91's Avatar
The service connector on Honda's is behind the PS kick panel.
The bottom pic is for the center console.
I just swapped my dash. There is a connector behind the cig lighter console that just plugs in, I am not sure what the wires go to, but that looks like that plug. The little one I think is for the cig lighter and lights around there.
DO I SPY A MAD TYTE RARE JDM SKUNK2 ECU y0?
Old Mar 30, 2005 | 07:34 PM
Timmay's Avatar
Default Re: (Cray91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cray91 &raquo;</TD></TR><TR><TD CLASS="quote">The service connector on Honda's is behind the PS kick panel.
DO I SPY A MAD TYTE RARE JDM SKUNK2 ECU y0?</TD></TR></TABLE>
well my cigarette lighter is plugged in, that wire comes from the top harness, my climate control is plugged in, basicly i dont have anyting unplugged that those 2 could plug into
and the ecu is a skunk2 p28
Old Mar 30, 2005 | 08:26 PM
sebas's Avatar
the second one looks like the plug Ive been looking for to hook up my hazards. Do your turn signals work ? Does anyone know where i can find a plug like the second one ?
Old Mar 30, 2005 | 08:29 PM
litterbox's Avatar
I am a (Trial User) Army
Didn't read all the other posts but:
1. Ground for the underdash harness. It goes behind your cluster on the right hand side of the steering support.
2. That either goes to the back of the climate control OR it's the other part of the heater harness that plugs from the heater core to the fan blower.
Old Mar 30, 2005 | 08:38 PM
Timmay's Avatar
Default Re: Where do these plugs go(dash wiring) (litterbox)
yea i have the harness hooked up from the climate control
and my fan blows air
hmmm who knows
Old Mar 30, 2005 | 08:44 PM
JTauto's Avatar
Was your car an auto at one time? The big plug looks like something tat would plug into an automatic mechanism but i could b wrong.
Old Mar 30, 2005 | 08:48 PM
litterbox's Avatar
Default Re: Where do these plugs go(dash wiring) (wickedhatch18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">yea i have the harness hooked up from the climate control
hmmm who knows</TD></TR></TABLE>Does your fan blow heat? It could be the plug that goes from the heater core to the fan blower(in the middle)
Old Mar 30, 2005 | 08:57 PM
Timmay's Avatar
no heat, i dont have hoses going to the motor yet
Old Mar 30, 2005 | 09:01 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">no heat, i dont have hoses going to the motor yet</TD></TR></TABLE>What did you use to cork the holes on the engine? I used rubber stoppers and one time driving one blew out and I lost all coolant.
Old Mar 30, 2005 | 09:04 PM
Timmay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">What did you use to cork the holes on the engine? I used rubber stoppers and one time driving one blew out and I lost all coolant.</TD></TR></TABLE>
hook hose from one side to the other
Old Mar 30, 2005 | 09:06 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">hook hose from one side to the other</TD></TR></TABLE>That's soo simple, yet genius! I shoulda just got hose.
Old Mar 31, 2005 | 02:29 AM
SIcivicHATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">fixing **** behind my dash today, found a few unused plugs
any ideas? </TD></TR></TABLE>
The first one is a ground so put it anywhere. You see on the picture where it is white there should be a tab that is bolted to the steering column support brackets. But if there is not just ground it anywhere
The second one.. first take out your center console... You will see a spot to plug it in where the metal dash support is. Look around may have worked its way under your carpet or something.
