help with autometer air/fuel ratio gauge
Old Jan 26, 2002 | 06:01 PM
Cyber ITR's Avatar
Default help with autometer air/fuel ratio gauge
that damn freakin thing only stays in lean
Old Jan 26, 2002 | 06:27 PM
maxim's Avatar
Default Re: help with autometer air/fuel ratio gauge (VTEC_SiR)
Are you sure you have the purple wire tapped nto the correct WHITE wire? There are several white wires, but all have some other color(one wth a small grey dotted lne and one wth a thin small red stripe, one wth green). The one you are looking for is thicker than the other wires and it is SOLID white(no other colors).
Old Jan 26, 2002 | 07:05 PM
B16A1-EF9's Avatar
Default Re: help with autometer air/fuel ratio gauge (maxim)
Your o2 sensor could also be bad. Not bad enough to trip the CEL but bad enough that the F/R gauge doesn't read properly.
Old Jan 28, 2002 | 04:41 PM
wonny's Avatar
if the O2 sensor was bad you would be reading RICH, like me.
Old Jan 28, 2002 | 08:03 PM
ck279's Avatar
Default Re: help with autometer air/fuel ratio gauge (wonny)
Double, triple, quadruple check your connection. I mean positive, ground, and sending lead. I'll tell you this much. Mine was stuck.....fixed, in green for a few days before I realized that if the unit is not getting any signal from the O2 sensor (hence the bad connection) is will stay pinned in the green. Just the way the unit works without any input voltage. So, your constant red may be a similar dilema.
moncrease
Mar 30, 2008 07:53 AM
adamrich33
Mar 26, 2008 01:23 PM
btrim23
Feb 11, 2005 09:36 PM
ZexyAccord
Nov 13, 2004 11:15 AM
integra0260
Jul 28, 2001 03:35 PM
