Q's about claying block
Old Mar 29, 2005 | 08:15 PM
hybridnorth's Avatar
Default Q's about claying block
Im getting all geared up to clay my motor, but i got a question, they say to advance your cams as far as you think your ever gonna go, then rotate your motor and re-clay.
just keep retarding it till its ok? or worse case senario go to a smaller cam?
b16 block
ctr pistons
gsr head
supertech valves
comp stage 3 cams
Old Mar 29, 2005 | 10:47 PM
rjay8604's Avatar
Default Re: Q's about claying block (hybridnorth)
Well, advance the intake cam as much as you think it might see when you tune it, Then do the same for the exhaust except retard it as much as you think you will. For example i did +5 intake and -6 exahust because i foresee these as the maximums i will ever advance/ retard the setup.
Old Mar 30, 2005 | 06:35 AM
Default Re: Q's about claying block (rjay8604)
cool, so if i advance as far as i think ill go and its too much, then just dont go that far
Old Mar 30, 2005 | 07:05 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">Well, advance the intake cam as much as you think it might see when you tune it, Then do the same for the exhaust except retard it as much as you think you will. For example i did +5 intake and -6 exahust because i foresee these as the maximums i will ever advance/ retard the setup. </TD></TR></TABLE>
Exactly. I used +6 / -6.
Good luck.
Old Mar 30, 2005 | 09:18 AM
rjay8604's Avatar
in other words, don't go to far or you'll have to reclay it. And its a PITA in th first place. So just put it at some reasonable settings like +6, -6. You'll probably never even tune them that far but it gives you a good margin of safety.
Oh yeah....good 1/4 mile b16 low 13's in a EH...nice
Old Mar 30, 2005 | 02:08 PM
import_trung's Avatar
just make sure u lock in vtec lobe when doing it.
Old Mar 30, 2005 | 05:07 PM
5thgenallmotor's Avatar
Default Re: (import_trung)
I was going to say the same thing!
tempsohc
Apr 15, 2011 11:09 PM
jyang67
Apr 30, 2008 08:04 AM
MiMiK
Jan 19, 2008 03:39 PM
locote
12
Jul 31, 2006 06:40 PM
revolt_allmotor
Sep 21, 2004 02:35 PM
