what the F___k is wrong with my car?!?!?!?! help help
Old Mar 29, 2005 | 06:54 PM
J_Bones's Avatar
Default what the F___k is wrong with my car?!?!?!?! help help
before reading excuse my language
i was driving normally as usual! i had to stop so i (step on the clutch and try to put it in neutral) and it wouldnt go into neutral! im like what the ****!...why wont in go into neutral, so before i stall i ******* forced it into neutral. Then i pulled over and tried it again! i finally get it going 1st gear into second (with a little tug) then it wont ******* go into third? and it sounds all crunchy! its still happening....! what can be the issue?
basically im having a BITCHY *** time putting it in gear and taking it out!
any help? its going into honda tomorrow...
Old Mar 29, 2005 | 07:49 PM
dc5 jared's Avatar
Default Re: what the F___k is wrong with my car?!?!?!?! help help (team ERA 5)
do u have a cold air intake?
Old Mar 29, 2005 | 09:46 PM
J_Bones's Avatar
Default Re: what the F___k is wrong with my car?!?!?!?! help help (dc5 jared)
yes...
Old Mar 29, 2005 | 10:00 PM
dc5 jared's Avatar
mite be the tranny shift weight?... i believe thats what its called thats hitting the cai piping. a few people on this board experienced it, including myself. its should be tuff to shift in 1st 3rd and 5th. and tuff to pull out of those gears.
im sure someone else can chime in and tell u what this exact problem is called. (if this is the same problem)
Old Mar 30, 2005 | 06:01 AM
t o m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5 jared &raquo;</TD></TR><TR><TD CLASS="quote">mite be the tranny shift weight?... i believe thats what its called thats hitting the cai piping. a few people on this board experienced it, including myself. its should be tuff to shift in 1st 3rd and 5th. and tuff to pull out of those gears.
im sure someone else can chime in and tell u what this exact problem is called. (if this is the same problem)</TD></TR></TABLE>
yea could be. u gotta install the cold air intake while in 5th gear. u da man jared
Old Mar 30, 2005 | 08:53 AM
J_Bones's Avatar
Default Re: what the F___k is wrong with my car?!?!?!?! help help (integra type s)
even with the ep3? the dc5 injen cai and ep3 injen cai seem to be in different locations
Old Mar 30, 2005 | 08:58 PM
civicvtec1ps's Avatar
Yes, same thing for ep3 and dc5.
Check the shift linkage.
Might be hitting the piping.
Old Mar 30, 2005 | 11:04 PM
rick_2002's Avatar
my friend had that same problem on his ep3 i had the same problem with my rsx what i did was put the rubber fitting that goes to the throttle body as far out as possible then the intake pipe as far out to thatway it doesnt hit anymore. on mine i couldnt go into 5th cause it would pop out of gear now i have no more problems.
b20bFourDoorCivicLX
Transmission & Drivetrain
Jan 30, 2012 04:27 PM
lokooo
Feb 25, 2005 02:50 PM
Ham'ed Hatch
Mar 30, 2003 07:40 AM
Random.Hero
Oct 23, 2001 07:21 PM
