b16 measurments quetions
Old Mar 29, 2005 | 04:52 PM
EFMAN's Avatar
Default b16 measurments quetions
ok what is the stock bore size,of a b16
and i am rebuilding my b16 with new rings and bearings and gaskets .
i was wondering how it's going to affect my motor if i put a mr.gasket head gasket .30" size on it . what will it raise the compressoin to and how should my stock motor take It and over all what you guys think about the idea.
thanks
Old Mar 29, 2005 | 04:59 PM
stockmr2's Avatar
Default Re: b16 measurments quetions (EFMAN)
stock bore is 81mm and .030 is a stock 3 layer gasket
try this
http://www.c-speedracing.com/h...c.php
Old Mar 29, 2005 | 05:18 PM
EFMAN's Avatar
Default Re: b16 measurments quetions (stockmr2)
are you sure thats right when lookin to buy a head gaskit there either 82 or a 85 bore . and lookin at a chart about toda head gaskits it said :
b16
.6mm-11.6:1 compresion
.8mm-11.4:1 compresion
1.0mm-11.2:1 compresion
heres the link to were i saw this and the gasket i want to buy
http://www.modacar.com/product...aheg/
and the one i want to buy is at nopi.com - catalog b16 head gaskit mr.gaskit .
if anybody cares
Old Mar 30, 2005 | 12:13 AM
stockmr2's Avatar
pretty sure of it.
everywhere ive seen it was 10.2:1 usdm and 10.4:1 jdm
if you got to the todaracing.com the c/r is based on a motor with toda racing pistons which shows it raised above stock.
Old Mar 30, 2005 | 07:18 AM
97L-esVeeTeg's Avatar
stock is listed as .029, if you measure it, its more like .026, so the .030 HG should see a small drop in compression, for a USDM B16 probably closer to 10-.1:1
I like OEM honda, whenever possible.
Old Mar 30, 2005 | 10:42 AM
EFMAN's Avatar
Default Re: b16 measurments quetions (97L-esVeeTeg)
well what kind of compresion gains would the ctr head gasket give me and were could i find it if i want to use it
Old Mar 30, 2005 | 02:17 PM
stockmr2's Avatar
the mutilayer headgasket says .029 and 2 layer .019 and the 1 layer is discontinued cause they leak too easy
Old Mar 31, 2005 | 11:48 AM
EFMAN's Avatar
will i am lookin for a 2 layer gaskit were should i find it ? thanks for the help
Old Mar 31, 2005 | 07:16 PM
EFMAN's Avatar
Old Apr 1, 2005 | 05:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFMAN &raquo;</TD></TR><TR><TD CLASS="quote">will i am lookin for a 2 layer gaskit were should i find it ? thanks for the help </TD></TR></TABLE>
you could buy an oem HG and pull the middle layer out or you could get cometic or another company to make you a custom gasket...or you could get one of the thinner HG on the market like, mugen or spoon, which are basically stock HG with middle layer pulled. You have many options.
hondaex99
Mar 4, 2010 06:22 AM
H-series LX
Aug 4, 2005 12:40 PM
grenthang
Feb 4, 2004 09:29 PM
grenthang
Feb 4, 2004 07:15 PM
vspec12
Apr 12, 2002 04:50 PM
