Broken Swaybar End links?
Old Mar 29, 2005 | 04:19 PM
6thGenPowa's Avatar
Default Broken Swaybar End links?
I have a 00 Accord sedan and replaced my suspension back to stock but I keep hearing clunking noises when I go over bumps and dips. I checked it out and tightened everything and it appears that the front sway bar end links wont tighten.
The nut just keeps turning with the bolt in either direction and I cant hold the other end because of that funny looking cap on the other end. Is it broken or is there something I am missing to tighten the sway bar end links?
PS: NEW Omnipower USA full coilover setup for the 6th gen accord now for sale
Modified by 6thGenPowa at 8:23 PM 3/29/2005
Old Mar 29, 2005 | 07:24 PM
6thGenPowa's Avatar
Default Re: Broken Swaybar End links? (6thGenPowa)
little night bump
Old Apr 9, 2005 | 01:10 PM
yoej8's Avatar
not sure but for the si rear sway bar, to tighten down the endlinks you need an allen wrench which goes in the middle of the bolt. size i believe 5 mm.
bigblockh22
Sep 6, 2012 09:03 AM
a1k0n
Feb 17, 2002 08:57 PM
a1k0n
Feb 17, 2002 12:38 PM
