Clifford alarm missed up! Help!
Old Mar 29, 2005 | 02:58 PM
YiNYaNg's Avatar
Default Clifford alarm missed up! Help!
My friends clifford alarm stop working and at the same time the power locks and driver side power window stop working too.
I checked all fuses and messed around with the alarm a bit and it blinks the lights like it's arming & disarming when i hit the remote button but it doesn't make any beeping sound anymore and the LED on the dash doesn't blink anymore it just stays on. And it doesn't even sense any shock when I bang on it when it's armed.
it's a 1993 Honda Civic Coupe Ex
Oh ...Yeah..I plugged the alarm too and the powerlocks and driverside window still doesn't work...
I'm just stumped...HELP!
Old Mar 29, 2005 | 02:59 PM
YiNYaNg's Avatar
Default Re: Clifford alarm missed up! Help! (H-T)
Really sucks having to open your door instead of the window at drive throughs...
Old Mar 29, 2005 | 03:13 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T &raquo;</TD></TR><TR><TD CLASS="quote">My friends clifford alarm stop working and at the same time the power locks and driver side power window stop working too.
I'm just stumped...HELP!</TD></TR></TABLE> If the LED stays on, the alarm is in valet mode, and only the doorlocks will work, [keyless entry] when you arm/disarm and the parklights will flash, as for the powerlocks and window on drivers side not working, unless a window rollup mod. was installed the alarm will have nothing to do with that, as for the doolock, if its only the drivers door that doesn't work, its not the alarm, it may be the doorlock and window motors or just a wiring problem. 94
Old Mar 30, 2005 | 07:40 AM
YiNYaNg's Avatar
Default Re: Clifford alarm missed up! Help! (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> If the LED stays on, the alarm is in valet mode, and only the doorlocks will work, [keyless entry] when you arm/disarm and the parklights will flash, as for the powerlocks and window on drivers side not working, unless a window rollup mod. was installed the alarm will have nothing to do with that, as for the doolock, if its only the drivers door that doesn't work, its not the alarm, it may be the doorlock and window motors or just a wiring problem. 94</TD></TR></TABLE>
How do you get the alarm out of valet mode?
The siren doesn't make any sound too. I tested it by plugging the siren to a +/- and it goes off loud but the alarm doesn't seem to be sending it power to beep it.
Old Mar 30, 2005 | 08:58 AM
YiNYaNg's Avatar
It's a Clifford Matrix (old model) & the valet 2wire white pin is not hooked up.
Old Mar 30, 2005 | 09:02 AM
fcm's Avatar
fcm
Old Fart
The siren doesn't make any sound too. I tested it by plugging the siren to a +/- and it goes off loud but the alarm doesn't seem to be sending it power to beep it.</TD></TR></TABLE>It's in the owners manual, if you don't have it , go to http://www.dei.com and download it.
PS With most of the older Cliffords you turn on the ign.and push and let go of the valet switch w/in 10 sec. to put it into or out of Valet, on the Matrix 1,2 and 3 you can also do it with the remote press the arm/disarm button then the trunk release button then the arm/disarm button again, one right after the other.
Modified by fcm at 6:18 PM 3/30/2005
mprznorth
Audio / Security / Video
Sep 8, 2012 01:09 AM
kirbyno1
Jun 28, 2009 10:15 PM
97Alex
Jan 29, 2004 04:32 PM
eg686
10
Mar 25, 2003 02:26 PM
balistic CRX
Dec 31, 2001 10:02 AM
