Well, it finally happened, I think I blew my motor :(
Old Jan 26, 2002 | 03:11 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Well, it finally happened, I think I blew my motor :(
Well, I heard a big *** boom under my hood down the track Friday night, but I still drove the bitch home anyway. It was barely able to keep a idle and it had no get up at all. I get up this morning and check the plugs and I always like to go backwards cause usually #3 or #4 go bad. #4 fine, #3 fine, #2 fine, #1 The entire porcelin has decintegrated and the plug is like ripped in half. I replaced the plugs and tried to start the car again and it still runs like poo poo. Terrible idle. I'm pretty sure I chipped at least 1 valve, maybe more. My friend is coming with his compression tester tomorrow, so we'll see how the compression is across the board. Now, some of you may think "He didn't blow the motor" Well, it depends what you consider blowing the motor is. My idea is chipping or bending valves, holes in the block, etc... The worst part is I prepaid for an Autocross session tomorrow and I now I can't go.
Old Jan 26, 2002 | 03:15 PM
EPGONZALEZ's Avatar
Default Re: Well, it finally happened, I think I blew my motor :( (RealTypeR)
are you sure it wasnt a backfire? i had a pretty bad one that took out my t-body..
good luck!
ep-who loves nitrous...and even more so on cars...
[Modified by EPGONZALEZ, 4:15 PM 1/26/2002]
Old Jan 26, 2002 | 03:16 PM
GarageQueen213's Avatar
New User
Drink a couple 40's... Take off your NAAWWSS and take it in for warranty work..
Back when I had a 91' AWD Talon TSi, I detonated 2 spark plugs where there was no porcelin left on the plugs too, 19lbs of boost on stock turbo and fuel.. Luckily replacing the plugs fixed it.. Good luck.
Default Re: Well, it finally happened, I think I blew my motor :( (EPGONZALEZ)
My friend had a backfire as well, but it set his air filter on fire, at least I had no fire.
Old Jan 26, 2002 | 03:17 PM
Bbasso's Avatar
ahh man, you can still start it? if so it anit blown!
think positive
Old Jan 26, 2002 | 03:18 PM
It any Florida boys are interested in tearing apart my motor Sunday night, give me call. I may do that just so I know what I am getting myself into with the dealership
D's Avatar
D
JESUS... you guys take that "burn it to the ground" poo poo literally....
you still want a VAFC installed? if you buddy dosn't come by with compression tester... gimme a call... have one in my toolbox.
D
Old Jan 26, 2002 | 03:21 PM
TypeR1558's Avatar
New User
RealType,R
I hope everything is working out okay. Thats a shame to hear, and i bet the repairs are expensive.
What did you do wrong with the nitrous? How long were you running the nitrous? How many shot, and what type of system? Single-fogger dry or direct port?
Jon
Old Jan 26, 2002 | 03:23 PM
Jmm0056's Avatar
Default Re: Well, it finally happened, I think I blew my motor :( (TypeR1558)
sorry to hear that man, hopefully it wont be all that bad, hurry and get that compression test done, BTW what are normal itr compression test numbers supposed to be?
Old Jan 26, 2002 | 03:39 PM
citanest's Avatar
New User
bent valves? over-reved? or just ka-boom and gone during racing?
Sorry to hear that. Hope you can get it fixed with minimal cost.
Old Jan 26, 2002 | 04:04 PM
Default Re: Well, it finally happened, I think I blew my motor :( (citanest)
I think normal compression is 240. I've never misshifted or powershifting. I'm running a single fogger NOS 70 shot wet kit. It just went boom during 2nd gear (maybe that explains the poo pooy times. ) I'll keep you all posted. This is me
Old Jan 26, 2002 | 05:15 PM
chad's Avatar
Moderator
marc you probably toasted your rings!!! that's what happened to mine....i drove on mine for the last 2 months....compression was 50-60-180-185 (B16a).....soooooo.....finally put a new motor in last night!! i love torque!!!
Old Jan 26, 2002 | 05:26 PM
FAST94GSR's Avatar
New User
Default Re: Well, it finally happened, I think I blew my motor :( (Chad (i'm back))
DAmn Mark you got all the luck man. That explains your low mph. What do you mean by running rough? You either toasted the rings. or burned a valve(s) Hope you got money for a rebuild. NOt sure if dealer is gonna cover it.
Old Jan 26, 2002 | 05:39 PM
B2FiNiTY's Avatar
Dang man. Good luck getting it fixed.
Old Jan 26, 2002 | 08:24 PM
Default Re: Well, it finally happened, I think I blew my motor :( (B2FiNiTY)
Well, we'll figure it out soon. I just hope I can get it home! My buddy said to take the NOS kit off and go the dealer and just say "I was driving at like 7000 and got on it when I heard a noise under the hood and now the car doesn't run right!! FIX IT!"
Old Jan 26, 2002 | 08:30 PM
Pinhead's Avatar
New User
Dude that sucks im sorry man......if ya need anything let me know it's happened to me once
Old Jan 26, 2002 | 09:17 PM
Default Re: Well, it finally happened, I think I blew my motor :( (typerman1358)
Keith - answer your fuggin phone man, I've tried to call you all night to explain
Old Jan 26, 2002 | 09:18 PM
Oh yeah, I just remembered - WE-TODD-DID racing in FULL EFFECT!!
Old Jan 26, 2002 | 09:28 PM
Total'd GSR's Avatar
New User
Marc,
That fuggin sucks bro... And to think I just saw you driving that b!tch the other day. Sorry to hear about it man. Later.
Matt
Old Jan 26, 2002 | 09:54 PM
Warren's Avatar
Wrong-Way Wang
Your buddy is an ***.
Warren
Old Jan 26, 2002 | 11:07 PM
Jmm0056's Avatar
Default Re: Well, it finally happened, I think I blew my motor :( (Warren)
what kind of naawwwwws kit are you running? i think i have read that you have a NOS brand system but is it a wet kit or dry?
Old Jan 26, 2002 | 11:36 PM
blackANESE's Avatar
Make sure u change ur oil if u do this, the dealership will know right away u were using nitrous if u have the same oil u were squeezing on in there.
Old Jan 27, 2002 | 12:06 AM
Default Re: Well, it finally happened, I think I blew my motor :( (captainJDM)
I just changed it two days ago, think it'll still make a difference? RealTypeR - who is drinking away the sorrow hahahaha
Old Jan 27, 2002 | 12:31 AM
forcefed's Avatar
yes thats great.. one less honda..
now buy a mustang ditch out the motor and put in a built 302 in tune the carb and win the streets
Old Jan 27, 2002 | 12:33 AM
Duck Sauce's Avatar
Default Re: Well, it finally happened, I think I blew my motor :( (pushrod punisher)
Pushrod, I think he wants a car that doesn't break down daily. So a FORD is out of the question.
