Car is Dying Supposely starter is bad Need HelP!!! already searched
Old Mar 29, 2005 | 09:45 AM
EM1_GIL's Avatar
Default Car is Dying Supposely starter is bad Need HelP!!! already searched
here is my story yesterday i was driving and i noticed my radio was turning on and off by itself so i just shut the radio off.
then at a stop i feels like my car is about to die out and i pull to a light and its bogging like crazy and all the lights are dim.
i shut the car off and wait a few seconds and try to start it again. Car wont start and i hear a crazy frying noise when i turn the key.
pop the hood check the usual everything seems fine. put key back in ignition and all lights light up fine try to start again Frying noise again and everything gets dim.
let car roll backwards and pop clutch car starts. dies all the way home(car will not start unless i push start it)
go home pull code 2 o2 sensor probably unrelated....
get friend to start car while i see where sound is coming from and it is coming directly from the starter remove starter and autozone said it was bad.
gonna replace it, but why was the car dying on when its on i would thought it was the alternator???????
any help or ideas would be appreciated.
Old Mar 29, 2005 | 10:04 AM
Terrible One's Avatar
Default Re: Car is Dying Supposely starter is bad Need HelP!!! already searched (EM1_GIL)
maybe since the alternator is dead, so is the battery?
Old Mar 29, 2005 | 10:07 AM
ironlung78's Avatar
maybe the starter grounded out the circuit so the alternator could not charge the battery
EM1_GIL's Avatar
Default Re: Car is Dying Supposely starter is bad Need HelP!!! already searched (ORiG1NaLKhMeRsTA)
they said the starter is bad and that where the noise was coming from. but why was the car shuting off?
Old Mar 29, 2005 | 10:09 AM
EM1_GIL's Avatar
Default Re: Car is Dying Supposely starter is bad Need HelP!!! already searched (sidesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi &raquo;</TD></TR><TR><TD CLASS="quote">maybe the starter grounded out the circuit so the alternator could not charge the battery</TD></TR></TABLE>
if this is true would a new starter fix it? no one in town has a the starter in stock i have to be carless for 4-5 days
Old Mar 29, 2005 | 02:20 PM
EM1_GIL's Avatar
anybody else have any other thoughts?
Old Apr 4, 2005 | 06:07 AM
EM1_GIL's Avatar
ok the starter is fine and i just replaced the alternator so what the hell is goin on???
Old Apr 4, 2005 | 06:29 AM
2lua's Avatar
are you sure your got the right code?
code 2 = o2 sensor
code 20= eld.
check your code again.
Old Apr 4, 2005 | 07:43 AM
EM1_GIL's Avatar
Default Re: (2lua)
you know what your probably right i am so f@#* stupid all that work, time and money wasted.
Old Apr 6, 2005 | 05:46 AM
EM1_GIL's Avatar
UPDATE
it was throwing a code 20 and i replace the fuse panel and fix it
c00ker
Honda Civic (2001 - 2005)
Jun 23, 2011 06:45 PM
eg8ynot
Oct 5, 2008 09:29 PM
ibe2fly
10
Aug 12, 2006 01:22 PM
baked_beanz
Apr 27, 2005 05:40 PM
ultraforce77
Aug 14, 2004 09:09 AM
