NO VTEC
Old Mar 29, 2005 | 08:31 AM
tallguy's Avatar
Default NO VTEC
I have a 1988 crx dx with a b16 and no vtec. I did some searching found out that it could be the tps. then did some more searching and found out that the check engine light was on because the tps was bad. well i replaced the tps had it recalibrated and now the car drives allot better but the vtec still kicks on and off. the car drives great no stalls and no bogging. this is really starting frustrate me because i spent all this money and im getting nothing out off it.
Old Mar 29, 2005 | 08:41 AM
SiR Inspired ED7's Avatar
Default Re: NO VTEC (tallguy)
vtec needs only, rpm, oil pressure, speed, water temp. check these.
AbitAvenger's Avatar
does the speedometer work? enough oil in the car? its not throwing codes anymore right?
Old Mar 29, 2005 | 09:11 AM
tallguy's Avatar
No more codes as of now but i'll see if it throws one on the way to work. oil is good, checked the screens in the vtec solenoid and they were fine. what do you mean buy water temp???
Old Mar 29, 2005 | 03:28 PM
tallguy's Avatar
bump
Old Mar 29, 2005 | 03:30 PM
2kTeg's Avatar
car has to be at opperating temp for vtec to engage
Old Mar 29, 2005 | 03:40 PM
tallguy's Avatar
Ok now the car is throwing a code 7 and 17 ....whats wrong
Old Mar 29, 2005 | 03:43 PM
tallguy's Avatar
Default Re: (tallguy)
ok another thing that i noticed is that the old tps was facing up and the one that i put on faces down.
Old Mar 29, 2005 | 03:55 PM
2kTeg's Avatar
code 17 - no speedo no vtec
code 7 - tps
when you fix your codes your car will run much better... and vtec will work i would sugest you do a search about your tps, and check the cable going into your vss its common that they just wont sit right and you gatta mess with them a little
Old Mar 29, 2005 | 04:01 PM
tallguy's Avatar
Default Re: (2kTeg)
I just changed the tps and its calibrated.... .4 idle and 4.5+ wot where is the vss located. will the code 17 make it throw a 7 or did i just buy a bad tps.
Old Mar 29, 2005 | 06:29 PM
tallguy's Avatar
just a little more help
Old Mar 29, 2005 | 06:33 PM
CRX_Control's Avatar
does the speedometer tell you how fast you goin? if not then there is no vtec. code 17 is vehicle speed sensor .
Old Mar 29, 2005 | 06:35 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (CRX_Control)
TPS should point down as pictured here..
If it points up,that is most likely a DX tps which won't work...
does the speedometer work or not?
Old Mar 29, 2005 | 07:10 PM
StupidSlowRSX's Avatar
Default Re: (88DXCRX)
The VSS is located on the transmission. In the back of your guage cluster the speedo cable that plugs into the back of the cluster runs into the top of the tranny. Do you have the Vtec soli grounded? Does your cars temp guage work?
Old Mar 29, 2005 | 09:54 PM
tallguy's Avatar
Default Re: (StupidSlowCRX)
yes the grounds are good, the speedo works fine but kinda jumps around when you first start rolling. the only other thing that confuses me when the car heats up while im on the highway and i use my left turn signal the temp Gauge jumps up and the bright light signal comes on. they are also very dimly lit when the car is cold.
Old Mar 29, 2005 | 10:36 PM
CRseXy's Avatar
Check your grounds. I would say something is up with your grounds. I had a similar problem with the turn signal bright thing. It turned out to be my Engine block ground. I also tightend my neg battery cable.
Also, make sure your vss cable is all the way in. I had a bouncy Speedo, it turns that it wasnt pushed in all the way.
99jdm_itr
Nov 1, 2009 12:01 PM
supersonic782g
Jun 25, 2009 01:33 PM
skiracer8148
10
Feb 10, 2007 07:52 AM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
Hondasaurs
May 9, 2003 08:51 PM
