piston
what is the best piston set for my d15b2 block on the original honda parts. higher compresion. and what is the compression ratio
[Modified by maximedx, 10:54 PM 1/26/2002]
The HF blocks supposedly have 10.x:1 compression... i'm not sure how much of that has to do with the pistons, and how much to do with the head.
I've heard slugs from an older d-series teg engine are a popular swap. Not sure about compression ratios, but someone here is bound to know.
Not a single HF piston i've seen has had 2 valve releifs. All have had four, like normal.
so it makes sense that the hf uses the same pistions as the si/dx and the head gives it the higher compression ratio....
you could be right about the pistons- I am not 100% sure- but- the HF head may have a smaller combustion chamber because the 2 valves that are missing are filled in and possibly displace more volume than the valves they replace- just a thought. I'll look into the pistons.
im not sure if they would fit due to the 8 valve engine but d16a1 pistons have a higher dome to them. im not sure the differences in the actual d15b2 block compared to the rest of the d series blocks but if its the same bore they should drop in (course i dont know if the pin height is higher/lower on the hx pistons/rods). they have 4 valve pockets but a machine shop can bridge the two pockets on each side so you basically have 1 pocket on each side when you're done. if u did that you'd prolly be >11:1 compression.
1.6L pistons are 1/8" shorter, that is ALOT when it comes to compression numbers.
Add a .250" headgasket inplace of current one (.040), then tell me how badly the car motor sucks.
If you put a1 pistons in a a6 block you achieve a 10.8 c/r.. Not to sure what the c/r of a b2 with a1 pistons will be.. probably not to much more then stock b2. A1 pistons have very large domes. The CC of the ZC/a1 head is alot larger then the dx/si head, that is where the c/r is gained at.
To me it sounds like alot of work for nothing.. unless you got all this stuff laying around, or got it for dirt cheap.
I must say I do like the short stroke of the B2 at times... But I have seen bigger cranks in motorcycles..
Jeff
Jeff
SohcVtecCrix
Oct 15, 2002 07:10 AM
