Timing Adjusting Issues - need help
Old Mar 29, 2005 | 07:22 AM
NatedoggAZ's Avatar
Default Timing Adjusting Issues - need help
Just checked my timing last night on my JDM D15B. It has been runing like shiz so I went out and got a timing light to check timing. According to the light set at "0" the timing was exactly at 0BTC. I loosened the distributor and twisted it toward the back to I guess advance the timing. I cranked it back as far as it would go but I could only get it to 14BTC...and I have read a lot that it should be at 16BTC.
Is there sonething that I am missing or is there something else jacked with my car because it is still kinda running like ***.
THX...
Old Mar 29, 2005 | 09:37 AM
NatedoggAZ's Avatar
Default Re: Timing Adjusting Issues - need help (NatedoggAZ)
anyone?
Old Mar 29, 2005 | 09:38 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Arent there timing marks ?
Old Mar 29, 2005 | 09:56 AM
NatedoggAZ's Avatar
Default Re: Timing Adjusting Issues - need help (JDM_Ej)
Yes - there are timing marks and the most I could advance it was 14BTC....
thats why I think that there is something jacked with the timing
Old Mar 30, 2005 | 09:08 AM
NatedoggAZ's Avatar
TTT
Old Mar 30, 2005 | 09:31 AM
civic-4-ges's Avatar
Your belt could have slipped, or is not on correctly. Check your timing with the timing marks on the cam hear, and the tdc makr on your crank pulley. Tell us your results
Old Apr 4, 2005 | 08:34 AM
NatedoggAZ's Avatar
Default Re: Timing Adjusting Issues - need help (civic-4-ges)
well, when I got this motor I changed out the water pump and timing belt. I cant remember how I set it at TDC though... are the marks onthe cam supposed to be in line with the top edge of the block? Because there are some marks also underneath the cover that I might have set the TDC to...?
Old Apr 5, 2005 | 03:19 PM
NatedoggAZ's Avatar
N-E-1?
Old Apr 5, 2005 | 03:32 PM
suspendedHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatedoggAZ &raquo;</TD></TR><TR><TD CLASS="quote">I cant remember how I set it at TDC though...</TD></TR></TABLE>
Old Apr 5, 2005 | 04:41 PM
Wow...no response
There are two marks on the stock cam gear, they should be level with the head, along with the word "up" actually pointing up
Just set that, and set your crank to TDC
Old Apr 12, 2005 | 02:19 PM
NatedoggAZ's Avatar
so is it supposed to be like the left or right image? This is from the online shop manual:
why would there be two different ways to set TDC?
Old Apr 12, 2005 | 03:00 PM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatedoggAZ &raquo;</TD></TR><TR><TD CLASS="quote">so is it supposed to be like the left or right image? This is from the online shop manual:
why would there be two different ways to set TDC?</TD></TR></TABLE>
duh!!! 2 difference motors... when you check the timing did you jump the service check connector?
Old Apr 12, 2005 | 03:32 PM
LShatchie's Avatar
Default Re: Timing Adjusting Issues - need help (2lua)
Umm has anyone noticed I think he checked his timing wrong? As far as my Craftsman timing light, you are supposed to set the light to your specified timing, which would be 16 degrees. You set it at 0.
Old Apr 13, 2005 | 08:28 AM
Default Re: Timing Adjusting Issues - need help (LShatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">you are supposed to set the light to your specified timing, which would be 16 degrees. You set it at 0. </TD></TR></TABLE>
This is an adjustable light....
Old Apr 13, 2005 | 09:51 AM
NatedoggAZ's Avatar
when I checked my base timing - I had the light set at "0"...
I still had the light set at "0" when I rotated my distributor to advance the timing which I could only advance to 14 deg MAX...
car still runs like ***
dem0nk1d
Jun 27, 2012 12:39 PM
northemt88
Mar 15, 2008 12:57 AM
lsegcoupe
Dec 22, 2006 07:54 PM
ScottEK
Nov 2, 2002 01:15 PM
