Failed emissions test - 2x Nox levels
found out the CAT was gutted. I have access to a shop that can "make" my car pass or should I get a high flow cat? Friend told me jegs 3 way CAT is what I need. Its for 1990 integra GS 2 door.
get a new cat high flow or oem becuz u gonna have to keep payin extra money to pass every year. i had the problem until i change the cat
the stock piping would be 2.25" or ??? and do i get the
3-Way Converters with out AIR Inlet Tube
289-15037 2.25'' In/Out, 13.25'' Long $52.99
from jebs?
http://www.jegs.com/cgi-bin/nc...r=361
from jebs?
my buddy had a gutted cat and his motor was pretty much fully built....didnt pass the emission test and he put 6-7 bottles of rubbing alcohol in his gas tank with full premium gasoline...drove it for 10 miles or so and came back to the emission test and it passed.......I wouldnt do it ...but he said it passed........
Rubbing alcohol?
Just use octane booster if you want to cheat the system, and make sure you do some hard acceleration for a bit before you go take the test. Seems to help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rand0m »</TD></TR><TR><TD CLASS="quote">Rubbing alcohol?
Just use octane booster if you want to cheat the system, and make sure you do some hard acceleration for a bit before you go take the test. Seems to help.</TD></TR></TABLE>
thats what he did, put rubbing alcohol and it passed...........i wouldnt though.......
Just use octane booster if you want to cheat the system, and make sure you do some hard acceleration for a bit before you go take the test. Seems to help.</TD></TR></TABLE>thats what he did, put rubbing alcohol and it passed...........i wouldnt though.......
sicrx69
12
Jul 11, 2007 03:36 PM
88turdbucket
Jan 27, 2005 08:58 PM
