lolz...ok what can you use to hold the side moldings onto the car?
Old Mar 29, 2005 | 05:21 AM
rice a roni's Avatar
Default lolz...ok what can you use to hold the side moldings onto the car?
i'm repainting my rex and in the process of taking off the side molding i broke most of the clips by ripping it off. what else can i use to hold the side moldings onto the doors?
Old Mar 29, 2005 | 05:25 AM
dip-set's Avatar
Default Re: lolz...ok what can you use to hold the side moldings onto the car? (tyranosauras-rex)
glue them on, rubber cement, polyurethane, something along those lines
Old Mar 29, 2005 | 05:27 AM
137's Avatar
137
Default Re: lolz...ok what can you use to hold the side moldings onto the car? (dip-set)
I like to use brake fluid.
Old Mar 29, 2005 | 05:28 AM
ok i will try that stuff. hopefully it holds if it gets wet. brake fluid?? lolz whatever man. i think i should spray paint my car with that stuff eh?
Old Mar 29, 2005 | 05:49 AM
dip-set's Avatar
use the same glue they use for windshields, that holds up under water( polyurathane/urathane)
Old Mar 29, 2005 | 06:23 AM
J.P. 4rm The dPk*'s Avatar
3m double sided tape?
Old Mar 29, 2005 | 06:25 AM
dip-set's Avatar
Default Re: lolz...ok what can you use to hold the side moldings onto the car? (Mr Pho King)
that will work as well..
Old Mar 30, 2005 | 05:02 AM
wouldnt tape fall off when it gets wet?
Old Mar 30, 2005 | 06:41 AM
accordselux's Avatar
Me Gusta History
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyranosauras-rex &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt tape fall off when it gets wet?</TD></TR></TABLE>
Lolz yes it would! I would try the glue and maybe a few zipties
Old Mar 30, 2005 | 07:56 AM
Default Re: lolz...ok what can you use to hold the side moldings onto the car? (accordselux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux &raquo;</TD></TR><TR><TD CLASS="quote">
Lolz yes it would! I would try the glue and maybe a few zipties</TD></TR></TABLE>
how would you zip tie side moldings on?? lolz maybe drill a few holes but i dont want to do that.
95ejjj
Jan 30, 2006 05:01 PM
130R
Aug 18, 2004 12:57 AM
slammedcivic22
12
Feb 11, 2004 02:04 PM
snapcase318
13
Aug 8, 2003 07:34 AM
dohc-nyne
Jun 3, 2003 04:52 PM
