motor pinging
Old Jan 26, 2002 | 12:40 PM
S13 slide's Avatar
Default motor pinging
i m curious about the 91 hatch Si's stock fuel pump, how does it compare to say a fuel pump from a teg? would it be adaquate(sp.?) for 11.1.1 compression? what about the whole fuel system? i just got done w/ my little build up, Ls w/ Pr3 pistons ect. and i started up the motor and i hear a noise that sounds like pebbles are being droped into my cylanders. so that would be detionation. and my entire fuel system is stock, so would it be adaquate? im about to get a S-afc or help combat this. i just wanna hear some opionions. thanks
Old Jan 26, 2002 | 01:33 PM
fixhondas's Avatar
Default Re: motor pinging (bobo)
If the motor was cold and knocking it probably isn't pinging. Are you sure the valve releifs in the pistons cleared the valves? The stock fuel pump should be adequate- as long as it is functioning properly.
johnson_racing
Feb 5, 2010 10:21 AM
trooper0641
23
Apr 6, 2005 12:51 PM
Eluzion
Apr 11, 2004 09:51 PM
slow02ss camaro
Apr 6, 2003 08:59 AM
S13 slide
Jan 27, 2002 03:10 PM
